Oil Filter
Car Info: 2006 Subaru Impreza WRX STI
Oil Filter
Hey guys got my oil changed a week and a bit ago and noticed today that I'm leaking oil. Could this be from the oil filter not tight enough taking it back to the shop tomorrow. Also where is the oil filter looked all around for it tonight is it hidden by the plastic mount underneath.
Cam
Cam
If it's leaking after an oil change it will be coming from either the drain plug (overtightened and stripped, undertightened and loose, no washer/gasket) or the oil filter (loose or double-gasketed). It's also possible that they were sloppy and spilled some oil on the engine when pouring it in.
I hope you at least went to a real shop and not Jiffy Lube.
I live up here in Canada. I took it to the shop who has done all my performance modifications on my other car so I know he knows what he is doing this is the third oil change hes done for me and first time this has happened
the best way to figure it out is to take of the plastic sheet and look
we can speculate for days (and its not rare for us to literally do that here on i-club) but that honestly wont provide any conclusion
Thanks for all the advice took it in today had him clean the old oil off everything let it run for a bit i got full oil pressure and no leaks were seem to be found going back tomorrow and take another look underneath
there is no washer between the filter and the car. the washer sits between the drain plug and the oil pan. the filter has a rubber gasket that seals it, which should be lubed with oil prior to tightening, and now that i've finished reading the posts i can see that this was the issue.
fd777
Jun 12, 2010 09:05 PM
iLoqin
Jun 6, 2010 10:47 AM
nation
Apr 17, 2009 01:16 AM
JackHCChen
Nov 12, 2005 09:50 PM
wrxout
Oct 26, 2005 03:13 PM
