Help!! Stupid jerking and cannot have full level gas.
Car Info: Subaru impreza sti 2004/ spec c/ vf 37 twin scroll
-2004 STI 2.0 L Spec-C.
-VF 37 twin scroll turbo charger
-Full Hks hi-power exhaust system (silent)
-Catless down pipe
-Bosche 275 fuel pump accompanied with a fuel compressor (set at 3.10)
-K&N air intake (full system with induction and suction)
-Blitz dumb valve (adjustable)
-brimbo breaks, suspensions and etc.
-Stock 2004 sti TMIC accompanied with an I/C Spray system (could be set on auto)
-6 gears electric (DCCD)
-Tuned with average boost of 1.4 bar (almost 22 psi) and timing of 24-26 (as far i believe)
-Average of 305 whp
-0-60 miles in 4.5 seconds average in night or cold weather.
-Never filled with else than 95 octane.
Hi all.
I have re-tuned the car 6 months ago and right after tuning (remap) a cam-shaft sensor code popped (hesitation on second gear on 6-8 rpm). I got it replaced with a used sensor and re-plugged it to computer then no codes occurred.
Now I am having similar problems which i doubt is linked to that one.
Whenever I want to fill it with gas, always a quarter is missed (never at full level). I asked a mechanic friend of mine who said this is because of the "canister". I am also experiencing huge drop in fuel mileage.
As well, i have noticed a gas smell, rarely, when i'm accelerating at the 6'th gear from low speed (Mph 60 onwards)
I'm experiencing stupid hesitation as well on the third gear at Rpm 6. (which i believe is the camshaft sensor problem because code has flashed for a second and went off, same old problem, which i believe because the sensor i installed was used).
Am i correct in my guess?
Summary:
-no full fuel level
-gas smell when accelerating at 6'th gear (rarely)
-Hesitation and jerking at third gear, also rarely, at rpm 6, with a fast code flashing.
-vehicle's performance is never like before.
I will really appreciate any kind of advice guys.
-Catless down pipe
-Average of 305 whp
Hi all.
Summary:
-no full fuel level
-Catless down pipe
-Average of 305 whp
Hi all.
Summary:
-no full fuel level
-Catless down pipe
-Average of 305 whp
Hi all.
Summary:
-no full fuel level
code_hat
May 4, 2009 11:40 PM
EvoEater
Apr 1, 2003 09:18 PM
scootr
Nov 27, 2002 09:15 PM
