03 wrx front oxygen sensor Help
Old Jul 2, 2007 | 06:23 PM
knightsnke's Avatar
Car Info: 2003 WRX
Can anyone tell me or show me a picture as to where the front oxygen sensor is on the 03 wrx. thank you!
Old Jul 5, 2007 | 08:03 AM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
It's in the right side exhaust header piece.
Old Jul 15, 2007 | 01:05 PM
SUBARU_TECH's Avatar
you can get to the sensor by turning the front wheels full right or best yet take of the right front wheel.just ahead of the rotor you will see a small plastic panel on the wheel well.just undo the 3 plastic clips and its right there.you will have to undo the 2 plastic clipw that are attached to the brack et at bank1 coils.follow the harness up.a o2 sensor socket helps alot for this sensor
Old Apr 2, 2008 | 10:03 AM
NewShockerGuy's Avatar
Arrow
How much does a front 02 sensor cost?
I am getting weird timing issues with my 05 sti's idle and this might be the cause....
Any special tools to remove it and install a new one?
Thanks,
-Nigel
Old Apr 2, 2008 | 10:36 AM
VRT MBasile's Avatar
Thanks,
-Nigel
o2 sensor socket. Looks like a deep socket and has an opening along the side for the wires. You'll want to unplug the wiring harness first though so that it doesn't get too twisted up around the ratchet
Old Apr 2, 2008 | 06:17 PM
Mulder's Avatar
Car Info: 02 WRX WRB
Thanks,
-Nigel
Do some proper troubleshooting before just replacing parts, especially expensive ones. The front 02/AF sensor is around $200 so not something you want to replace on a whim. Remember that electrical parts are usually not returnable, and you definitely can't return it once it's used.
Anyway the sensor is closely monitored by the ECU, and if it were in fact defective you'd probably have a CEL with codes pointing toward the sensor.
Old Apr 22, 2008 | 06:01 PM
nosnam's Avatar
Car Info: 2003 subaru
i bought that sensor and it cost 200 bucks from advance with a 1 year warranty, from a suby dealer it cost 250 and no warranty except 90 days if they installed it. it takes 30 minutes from start to finish and I noticed better gas mileage and better acceleration too, I was driving around with a bad sensor for about 5 months.
Old Apr 23, 2008 | 05:55 PM
How does one know if the sensor is bad?
You by chance didn't take pictures of the install..etc?
Thanks,
-Nigel
Jimboi
Mar 29, 2012 08:27 PM
Peaty
May 30, 2008 09:58 AM
diz
Subaru OEM Parts For Sale
Jul 9, 2007 03:41 PM
diz
Jan 24, 2007 05:12 PM
imprezapilot
Jan 6, 2004 10:22 PM
