STI Parts...Electronics
Old Aug 1, 2011 | 11:47 PM
Island Style's Avatar
I have several parts left from my 04 STI...
1. Fidanza Lightweight Flywheel...BNIB...$200 (New $319.99 + Shipping) 9.5lbs
http://www.maperformance.com/fidanza...l-wrx-sti.html
Our aluminum flywheels are made from the highest quality 6061 T6 aluminum. The material is fantastic for strength, heat dissipation and of course reduction in weight. The friction surface we use is an icredibly strong 1045 steel. The flywheel friction plates are milled to meet our high specifications. A Fidanza aluminum flywheel can mate with any type of clutch material, including organic, kevlar, ceramic, metallic and sintered iron. We attach the replaceable friction surface with military grade aerospace fasteners. With these replaceable friction plates there is no need to replace the entire flywheel when the clutch or flywheel is at the end of it's life, saving time and money. The ring gears we use are also made from 1050 steel and are heat treated for durability. The flywheel ring gears are heated then pressed on and secured with grade 8 button screws. We were the first to utilize a stepped dowel system in most of our flywheel applications. This doweling method ensures that once the pressure plate is installed the dowels cannot be removed because they become locked into place.
2. Used Project Mu Rotors...Fronts Worn/Rears Good...$100 (5x100)
3. Ferrodo DS2500 Pads (Like New, front and rear)....$150
4. Alpine CDA-9887 (Top of the line Deck)...BNIB...$300
5. Alpine CDA-9847....$75
6. Pioneer CD Deck...$50
either pm me or text/call 457-0743
Thanks,
Brent
Old Aug 2, 2011 | 02:35 PM
Can't believe nobody wants to put on a lightened flywheel...
Lightened flywheels are a blast to drive...rev's quick!
Old Aug 2, 2011 | 09:20 PM
PSI-PWR's Avatar
Car Info: 04STi AMS Tuned
How worn are the rotors? Can they still be shaved & re-used? LMK
Old Aug 2, 2011 | 10:49 PM
Ditchhanger's Avatar
Staff Member
Car Info: 2001 RSTi Widebody
Brent...call me about the pads...
Old Aug 6, 2011 | 02:41 PM
bump
bump this up...
Old Aug 7, 2011 | 04:32 AM
AcCoRd N wRx Dd's Avatar
Car Info: 2003 wrx with hta68 1994 Honda accord h22a
How light is the flywheel? I have the 9 lb act and had 13 lb before that. Might help with sell.
vayrogar
Oct 30, 2011 02:03 PM
RavSpec
Vendor Group Buys/Specials
Sep 9, 2004 10:42 AM
RavSpec
Aug 25, 2004 03:26 PM
Imprezanator
Apr 19, 2003 08:51 PM
mehlt
Dec 8, 2002 11:30 AM
