FS: random wrx and legacy parts
Old Aug 6, 2012 | 01:35 AM
ka13wrx's Avatar
Car Info: 07 wrx tr
Got some random wrx and legacy parts for sale. All parts are in good to excellent condition and some brand new. PM, text, or gimme a call if you are interested. Kory 808-392-2607
Ichiba 15mm spacers 5x100 and 5x114 NEW $60 (set of two)
Ihciba 5 mm spacers 5x100 and 5x114 NEW $40 (set of two)
2010 and up legacy roof spoiler painted metallic grey $60
2010 and up legacy BC BR version coilovers $400
Old Aug 13, 2012 | 09:04 AM
ka13wrx's Avatar
Car Info: 07 wrx tr
bump
Old Aug 13, 2012 | 11:49 PM
Loading...'s Avatar
Car Info: 2011 wrx
whats the part number on those coilovers, trying to see if they fit my car
kevin
Old Aug 14, 2012 | 12:35 AM
zao96854's Avatar
Car Info: 2012 DGM WRX
will they fit on a 12 wrx hatch
Old Aug 14, 2012 | 09:23 AM
ka13wrx's Avatar
Car Info: 07 wrx tr
The part number for the wrx and the legacy coilovers are different, so Idk if they would fit.
Old Aug 14, 2012 | 09:31 AM
ka13wrx's Avatar
Car Info: 07 wrx tr
Anyone else know if they fit?
Old Aug 21, 2012 | 01:46 AM
Tech998's Avatar
Car Info: Impreza STI Sedan 2011
Bump for awesome price!
Old Aug 21, 2012 | 02:19 AM
Tech998's Avatar
08+ wrx suspension will interchange with 05-09+ legacy and 08+ foresters but not STI unless modified to fit. Spring rates are different between models that's why part numbers are different. I think legacy is little stiffer than wrx but I might be wrong.
Old Aug 21, 2012 | 02:24 AM
Heedz's Avatar
Nobody likes the tuna here
I have not heard that the GR/GH wrx and BP/BL legacy suspension is interchangable....
Old Aug 21, 2012 | 09:02 AM
ka13wrx's Avatar
Car Info: 07 wrx tr
thanks. bump price drop.
Old Aug 21, 2012 | 12:43 PM
Tech998's Avatar
GE/GH wrx and BL/BP legacy physically are identical. Front will bolt up as coilovers and rear too. But spring and struts are not easily interchangable because rear top hats are different on legacy. You can drill out the wrx top hat to accomidate the larger diameter shock shafts of the legacy struts but they are also taller than wrx. But more importantly, the rear trailing arm/ hub assembly geometry is different on legacy. That's why the spring rates are stiffer on legacy rears. So basically, the coilovers should go in but the spring rate is not the right ones. But for the asking price, you can't go wrong and shouldn't matter much if he's only on street not doing SCCA or anything cause aftermarket spring rates are higher than oem anyway
Old Aug 21, 2012 | 12:52 PM
Tech998's Avatar
I forgot to mention the struts are shorter on legacy so wrx can be slammed but like most full coilovers, the lower perch can be adjusted to make the overall coilover longer to adjust the ride height he wants.
Old Aug 31, 2012 | 12:17 AM
ka13wrx's Avatar
Car Info: 07 wrx tr
Bump
soggynoodles
Jun 28, 2011 06:50 PM
ImprezaRSDriver
Oct 29, 2010 12:01 PM
stirs
Oct 28, 2010 11:54 PM
aznsexrboy808
Hawaii Classifieds
Feb 6, 2009 04:31 PM
