shifting problem
Old May 19, 2004 | 12:04 AM
STi-LLlegal's Avatar
Car Info: DGM 2011 WRX Hatch
shifting problem
Anyone hear of problems in shifting to 2nd. It shifts like butter when I change at 3k or below, but when I rev to like 5000 and up, shifting into 2nd feels really notchy and hard. During normal driving its perfect, but when I went to the tracks 2 weeks ago I experienced that notchy shifting into 2nd and best time I did was 13.4. First gear is perfectly fine cuz I only slip it, but I just dump it when I shift to 2nd. I thought this was normal, but I called Schuman and talked to Braun and he said it shouldn't be doing that. So I'm bringing it tomorrow morning to Schuman so Ed can road test it. Hopefully its nothing too bad, like messed up synchros. Just want to know what you guys think.
Old May 19, 2004 | 06:57 AM
EtchyLives's Avatar
does it grind? Mine grinds into 4th from both 3rd and 5th unless I shift below 3k. Even then, sometimes. Mine is the synchros.
Old May 19, 2004 | 07:18 AM
sneezerboi's Avatar
I heard it happens with these gearboxes... I get the same things going into 2nd at higher RPMs...I was told to just ease it in and not ram it in there. If this is indeed abnormal then I have to get mine checked out too.
Old May 19, 2004 | 06:04 PM
brought it in today and ed took it for a test. he said it was normal but i should replace the tranny fluid.
Old May 19, 2004 | 07:00 PM
gdogg's Avatar
Car Info: 1973 Huevo Ranchero
how many miles do u have?
Old May 20, 2004 | 12:37 AM
6000
Old May 20, 2004 | 05:25 AM
gdogg's Avatar
6k and already changin the fluid.
hmm if u can, see if u can look at the fluid when they drop it.
Old May 20, 2004 | 03:13 PM
what is it supposed to look like? is it supposed to look like black engine oil or clear looking? braun said he's going to put synthetic tranny fluid instead of what the stock one has, which I don't know what it has.
Old May 20, 2004 | 07:55 PM
wrx~god's Avatar
on cold mornings my first to second goes in pretty notchy. when it warms up its as smooth as the other gears. I only have 1400 miles on the STI so let me know what happens after the fluid switch.
blue blurr
Jun 22, 2006 02:53 PM
burmis1
Oct 15, 2004 05:31 AM
MashiMOMO
15
Jun 19, 2003 11:12 AM
bagelcc
Jan 31, 2003 05:43 PM
NleahciM
Jan 6, 2003 07:18 AM
