Rear diff "Hooo" sound.
Old Jun 7, 2009 | 03:23 PM
Aeros's Avatar
Car Info: Pasoi!
Recently there has been a harmonic hooooo sound around 60-65mph under neutral load. I hope that its coming from the rear diff rather than the transmission. After doing some spot on research, I found that subaru released a tech service bulletin regarding this issue. Would they still cover this even not under warranty? Im not sure if anyone else had this issue here before.
The TSB;
Old Jun 7, 2009 | 07:39 PM
AMLIBERATOR's Avatar
Car Info: 2002 Subaru Wrx
same thing happens to me, more pronounced in 4th and 5th gear in my 04 wrx. under load its fine, but when i let off and coast in gear, there is a howling "hooooooooing" sound. im also thinking its the rear diff, too. havent changed the fluid yet, i gotta get on that.
Old Jun 7, 2009 | 07:40 PM
houdni's Avatar
Car Info: 06 STi
If your out of warranty ...its not covered under warranty....its just basically that a technical service bulletin to help techs diagnose certain problems and conditions...the only exceptions are when there is a factory recall on the vehicle...
if you want the TSB done...and your warranty is up...you would have to pay for the part as well as the time to install the parts...
Old Jun 8, 2009 | 10:18 AM
dub81's Avatar
E,Is the Sound faint or real noticeable? R180 FTW or drop a R300!! j/k!
cleofis
Jan 14, 2005 01:42 AM
supra_man
May 24, 2004 03:31 AM
supra_man
May 11, 2004 01:07 AM
EJ25RS
Mar 18, 2004 08:11 PM
el jeffe
May 31, 2003 02:17 PM
