problem when filling up gas
Old Jan 20, 2009 | 01:42 AM
ScoobyWho?'s Avatar
Car Info: "STI-EGO"
Ok so earlier i went to the gas station to fill up. My car's gas was at the 1/4 mark. I put $40 which i knew was enough to to reach full tank. Then the pump stopped at only $25 and i was like wtf? As i left, i looked at the meter and it was only at the 3/4 mark. This has happened to me about 3 times now. I was wondering if any of u guys also have this problem or know what's wrong and how to fix it. Thanks.
-Charles
Old Jan 20, 2009 | 02:37 AM
pimpsawse's Avatar
Car Info: camber toe
I also had this problem
best thing to do is spit on the nozzle before putting it in.
You'll get you moneys worth!!!!!
Old Jan 20, 2009 | 02:49 AM
pwnx0rz's Avatar
Car Info: '02 WRX wagon
what?
Old Jan 20, 2009 | 03:12 AM
rocker13's Avatar
Car Info: '86 corolla GT-S/'04 STi
that happens to me at tesoro most of the time. i just keep on filling after it clicks off.
Old Jan 20, 2009 | 03:16 AM
04sleeper's Avatar
it happens...try not holding the handle down full blast next time.
Old Jan 20, 2009 | 07:56 AM
june.rs's Avatar
Car Info: 07 pearl white wrx
dont you think that $45 is alot. when my car is 1/4, usually $25 dollars is enough to hit the full mark.
Old Jan 20, 2009 | 08:00 AM
Risk3233's Avatar
Car Info: STi (cornering, accelerating and braking hard).
This is a widely documented problem. Check IWSTI and search fuel sender.
My car does it. What you have to do is start the car up and turn it off at least once and maybe more than that. Mine does this intermittently and I used to get upset until I found out what the problem is. Mine doesn't do it every fill up and I notice that if I fill up closer to 1/2 tank it's less likely to happen.
I haven't called the dealer yet. Once I found out the cause, I just live with it.
Old Jan 20, 2009 | 09:50 AM
Bran808's Avatar
Does this mean that I'm a pervert, since I'm the only one laughing at Pat's comment.
Old Jan 20, 2009 | 09:54 AM
Max Xevious's Avatar
BanHammer™
Car Info: 2014 Forester XT
did you ever change out the fuel pump?
Old Jan 20, 2009 | 10:14 AM
alienbreed69's Avatar
Car Info: 04 sti now pulling hard but super greasy!!
im sure big d will agree with this one.......... charcoal cannister!!!!!!! mine has been doin this for a while now and i asked around and the only one with the answer so far has been ds barruuuu he said he removed or cleaned his cannister and the problem went away hope that helps.....
Old Jan 20, 2009 | 10:23 AM
ScoobyWho?'s Avatar
Car Info: "STI-EGO"
Nope, still stock.
Is the tank actually full even if the meter says its 3/4 full?
Old Jan 20, 2009 | 10:55 AM
BanHammer™
Originally Posted by ScoobyWho?
Nope, still stock.
more then likely, yes.
I have seen this before when a fuel pump was replaced and the level float was not installed back correctly, it will only register 3/4 of a tank.
its possible that your floater mech has gone bad, and why its happening.
good news! your low fuel light is on a different system and still functions correctly.
Old Jan 20, 2009 | 11:20 AM
Keainakoa's Avatar
Car Info: 2021 Crosstrek Sport
$40 to fill??? Damn!!! Most to fill my tank is $25 and that's almost running on fumes.
Old Jan 20, 2009 | 11:22 AM
BanHammer™
Originally Posted by Keainakoa
I think what he's trying to point out is that maybe the sending unit got messed up if you changed out the fuel pump.
yes
Old Jan 20, 2009 | 11:26 AM
Keainakoa's Avatar
yes
Didn't see your last post until I already posted mine. Kinda jumped the gun there.
