Power Window Woes...PLEASE READ...I'm stumped.
Old Aug 29, 2003 | 02:52 PM
IS2Scooby's Avatar
Pr0n King
Car Info: Turncoat Turbo
Maybe it's a ground control system? Check the ground for the motor... What about the relay?
Did you test to see if you could raise the windows with the r/f sub switch as opposed to trying it from only the master switch?
__________________
Old Aug 29, 2003 | 02:55 PM
IS2Scooby's Avatar
Pr0n King
Heheheh, sorry. I just meant the r/f window switch (and not the master control on the driver's door).
__________________
Old Aug 29, 2003 | 02:56 PM
IS2Scooby's Avatar
Pr0n King
The reason I ask is we had Lexus customers left and right claiming that their passenger front window motors were "burnt out"! Sure enough you try and roll the window up/down from the driver's master switch and it wouldn't work.
Hop over to the r/f seat and use the switch and the window worked fine. It turned out to be the master window switch.
Just hopin' it's something simpler than having to track down a open-circuit or short in the whole wiring harness.
__________________
Old Sep 1, 2003 | 07:40 PM
iNfEk's Avatar
Originally posted by JohnB
I figured it out. Whoever guesses what was wrong gets a cookie.
Was it a bad connection?
Old Sep 1, 2003 | 07:41 PM
IS2Scooby's Avatar
Pr0n King
Short in the switch?
__________________
Old Sep 1, 2003 | 07:44 PM
iNfEk's Avatar
Broken switch contact?
Old Sep 1, 2003 | 10:13 PM
oldmansan's Avatar
The window lock
switch was on?
San
Old Sep 1, 2003 | 10:14 PM
brento's Avatar
Car Info: 02 RS
it didn't fall of the tracks now? (i just incase since no on asks.)
just for fun. you didn't press the lock button on the drivers side to imbolize all the other windows?
