oil leak by the turbo side....
Old Oct 17, 2009 | 02:45 PM
danWrX's Avatar
Car Info: 09 WrX Pearl White 5dr hb / 04 Wrx White
can anybody help me to fix instead going on the dealer....
Old Oct 17, 2009 | 02:47 PM
03wrx46's Avatar
Car Info: 03 wrx [enter name here]
if its the 09 wrx wouldnt you want the dealer to fix it since its still under warranty?
Old Oct 17, 2009 | 03:03 PM
danWrX's Avatar
Wink
sori if i never specify which one ....the leak is on my '04 wrx....
Old Oct 17, 2009 | 03:25 PM
iNfEk's Avatar
oil leak... can you take a picture?
Old Oct 17, 2009 | 04:35 PM
danWrX's Avatar
i dont think that it will show on picture.....my friend in lex brodies is the one who take a look out on the leak and he told me its on the turbo side,he dont want to fix it b'coz that's not his expertise
Old Oct 17, 2009 | 04:42 PM
iNfEk's Avatar
That doesn't say anything by referring to the leak being on the "turbo side". You need more information and pictures if you want help.
Expertise has nothing to do with your situation of he didn't specify and articulate what he feels the problem is.
Aeros's Avatar
Car Info: Pasoi!
Maybe the clamp on the oil return line is loose? I had to fix that one once.
Old Oct 17, 2009 | 05:18 PM
03wrx46's Avatar
ahh makes sense
Old Oct 17, 2009 | 07:07 PM
danWrX's Avatar
i'll try to take a picture.....and post it asap.....
Old Oct 17, 2009 | 08:15 PM
Thug Nasty's Avatar
Car Info: Hi, I'm John.
could be a turbo feed or return line, could be a cam seal, could that lame half moon gasket, could be cam cover gasket, could be one of a hundred things. We need a littleeee more info.
Old Oct 18, 2009 | 07:45 PM
Anti-hero's Avatar
Car Info: Subaru PSM Wrx 05 w/ Mud guards Red 88 Conquest
Check Cv boot could be cracked and spraying grease on the underside.
Old Oct 18, 2009 | 08:01 PM
iNfEk's Avatar
that's definitely a possibility but grease and oil look different in consistency and color. when my passenger side boot rips it sprayed all over my front cross member but there was some residue on the up pipe and other areas in that area... definitely worth looking into but pictures speak a thousand words...
Old Oct 18, 2009 | 08:50 PM
BoOm's Avatar
Second on the difference. I had a cv boot leak on my WRX on the driver's side and it totally does not resemble oil.
Old Oct 18, 2009 | 11:03 PM
YuudaiSTI's Avatar
Car Info: 57 SM 04 STi, 04 Yamaha R6
I have a bad CV boot now. It gets EVERYWHERE!
Old Oct 19, 2009 | 10:49 AM
csubaru04's Avatar
Car Info: 04 WRX
any problems boosting or just leaking?
