looking for 08 STi parts.
Old Nov 13, 2010 | 12:50 AM
die_lawn's Avatar
Car Info: VF39'd EWG bugeye/ 99' Miata
well struts and springs to be exact. i figure i'd post on here and the classifieds. so if anyone has a set lying around and would either like to sell them or donate them, please be my guest =)
call 780-7955 thanks!
Old Nov 13, 2010 | 01:08 AM
Jrocko's Avatar
Car Info: 1989 Honda Civic, 11ʻ R1 & 09ʻ GSXR600
if they are for your FXT, Get 2010 WRX Springs and you can keep the Forester Struts.
The 2008 STI have horrible Spring rates. I put me on mine and I quickly took them off.
I just bought some WRX 2010 Springs 1 week ago and they feel so much better. Height is awesome too.
Old Nov 13, 2010 | 01:14 AM
die_lawn's Avatar
are they really? i'm trying to get this drop for cheap i guess..
Old Nov 13, 2010 | 08:16 AM
Bran808's Avatar
Hey Lorenzo, can you post or text me some pics? So the ride is noticeably better than the Sti springs? I would've thought the Sti springs would have better spring rates. How was the height affected? Higher or lower?
Old Nov 13, 2010 | 09:48 AM
Jrocko's Avatar
I will post some pictures today....
The height is about 2 fingers gap in the front and 3 finger gap in the back.
It might be because of the 19in Rims but I like the drop and the Ride.
08 STI suspension was horrible so in 2009-2010 they upgraded the Spring rate.
I should have took pictures of both springs next to eachother to show everyone the difference.
Old Nov 13, 2010 | 09:54 AM
04sleeper's Avatar
I saw Lorenzos xt yesterday and it was looking pretty nice.
Old Nov 13, 2010 | 11:05 AM
die_lawn's Avatar
so you kept the stock FXT struts and just swapped out the springs?
Old Nov 13, 2010 | 12:13 PM
lcjarrett's Avatar
Car Info: 2002 POS
Yes that's exactly what I did....FXT struts w/ 2010Wrx Springs
It was cool seeing you Justin, I am looking more and more into getting this XT up to par!
Old Nov 13, 2010 | 01:12 PM
R_T_I's Avatar
Car Info: Impreza
The 2008, 09, and 10 STI have the same spring rates. The 2010 STI SE has stiffer front and rear springs and larger anti-roll bars. The 2011 STI has rear springs even stiffer than the 2010 STI. I have not found anything that says the spring rate was increased in 09-10 for the STI. What info do you have saying the 09-10 STI has stiffer springs? I know the WRX spring rate and anti-roll bars were changed from 08 to 09.
Old Nov 13, 2010 | 03:58 PM
Jrocko's Avatar
^^^you can look at the Springs and tell that they are not the same. Like I said before I should have taken pictures but I was too excited at the time and I wanted to just install them.
Daniel (AccordnWrx DD) can Vouch for me and say that the springs are not the same.
Old Nov 13, 2010 | 04:09 PM
shaggadelic's Avatar
http://www.autoblog.com/2008/07/31/2...on-sti-tweaks/
Originally Posted by edmunds.com
Suspension Re-Tuned For Sharper Handling
Subaru significantly re-tuned the suspension on the 2009 WRX, resulting in sharper turn-in and more responsive handling overall. Front upper strut mounts are adopted from the STI. The front spring rate is increased from 26.5 N/mm to 38 N/mm, and the rear spring rate is increased from 24 N/mm to 34 N/mm. Diameter of the stabilizer bars is also increased, from 20 mm to 21 mm in front and from 15 mm to 16 mm in the rear. Suspension damping has also been re-tuned. Notably, the new, stiffer suspension tuning did not require any further reinforcement of the inherently strong Impreza body structure.
IIRC these spring were also the same now on the 09-10 sti's.
Old Nov 13, 2010 | 05:47 PM
die_lawn's Avatar
Hmm ok well i need that whatever will fit on my FXT and drop it lol
Old Nov 14, 2010 | 12:55 AM
Jrocko's Avatar
i have the 2010 Fronts Springs and the 2008 STI Rear springs if you want them?
just let me know.
Old Nov 14, 2010 | 01:32 AM
Jrocko's Avatar
Not a good Picture but it gives you an idea....
Old Nov 14, 2010 | 02:15 AM
markpaco's Avatar
Car Info: AWD/FWD/RWD
just let me know.
So are you running 08 STI front springs with 10 WRX rear springs?
If so, why did you keep the 08 STI springs in front?
