Help: any power steering guru's out there
Old May 4, 2006 | 12:17 AM
motomech's Avatar
Car Info: the daddy van beatin da bass
Question Help: any power steering guru's out there
Ive been having trouble with my power steering and from what Ive gotten from the few people Ive talked is that there is air in the system or the pump is going out. I am looking for someone with the experience to help determine the problem or point me in the right direction to a reliable shop I was going to take it to the dealer, but they wanted $95 just to diagnose. If anyone helps me I'll provide lunch and some cash.
I.M. me or call me at 389-0271
Brian
Old May 4, 2006 | 12:22 AM
hayn_wrx's Avatar
Car Info: 02' wrb wrx w/ RGII
did u check ur power steering fluid and the lines also ?...i had the same problem for a few days outta no were i had no power steering..n e ways i jacked up the car and check all the lines and sure enough one of the nut's was a lil loose so it was leaking..problem solved...hope this helps
Old May 4, 2006 | 12:33 AM
iNfEk's Avatar
also depending on your mileage it might be time for a power steering fluid change
Jon
Old May 4, 2006 | 12:53 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
What year is your car? How many miles?
You really gotta provide more info if you need help from "gurus"?
You might as well just say "I have a problem and I need help..." That is just as good.
Old May 4, 2006 | 01:12 AM
shaggadelic's Avatar
if u have an upgraded turbo the line could be resting against the turbo and melt. i caught it on mine and also a friend had his melt on him while he was driving. u may have a small leak. just guessing b/c not much info so going on my experience with it
Old May 4, 2006 | 01:26 AM
motomech's Avatar
sorry, its a 2000 forester withe about 76k. I check for leakage(Breifly) but found nothing, fluid level is full, although it acts as if low, jerking while turning left and right, but is fine when revving.
Old May 4, 2006 | 01:31 AM
ok throw my thought out i thought u were a wrx lol
wrx 03i
Jan 10, 2011 04:27 AM
Latka
Oct 24, 2006 12:37 PM
dyepball1
May 18, 2006 10:23 AM
Toiletbrush
Sep 8, 2005 12:58 AM
RussB
Jun 2, 2005 05:27 PM
