Brake Lights wont WORK!! Need Help!!
Old Apr 1, 2014 | 01:51 AM
MyWagon's Avatar
Car Info: 07 WRX sport wagon
Hey I have a 07 wagon and ALL of my Brake light wont turn on! but my signal and parking tail light works. Does anybody recommend a good shop to get this fix?
Wil
-I checked all the Fuses (Good)
-No Loose wiring (good)
Old Apr 1, 2014 | 05:41 AM
abakja1's Avatar
Car Info: 08 Nissan Titan, 12 MazdaSpeed 3, 15 Honda CRV
Wil
,.....and you swapped out for new bulbs too??
Old Apr 1, 2014 | 07:48 AM
PSBeachBum's Avatar
Car Info: my wife crazy with buying parts
Relay?
Old Apr 1, 2014 | 11:00 AM
spinplay01's Avatar
From: Ice Palace...not the meth lab, the skating rink.
Car Info: 1995 dodge neon
If all brake lights stopped working at the same time (and you checked all fuses) it is most likely the switch behind the brake pedal arm.
Easy fix usually.
Remove a bulb, check for power when pedal pressed. If power...change bulbs.
If no power at bulb, check switch. It is easily removed and check for continuity when little button pressed.
If it is neither of those, you may need help fixing it.
Old Apr 1, 2014 | 11:09 AM
02RS25's Avatar
Originally Posted by spinplay01
If all brake lights stopped working at the same time it is most likely the switch behind the brake pedal arm.
+1. If all 3 brake lights dont work, its either a relay or the switch behind the pedal. Most of the time its the switch. Easy fix just a PITA working under dash.
Old Apr 2, 2014 | 03:02 AM
MyWagon's Avatar
Thanks for the help. I will check that out soon!
Old Apr 2, 2014 | 03:04 AM
MyWagon's Avatar
Does anybody have a picture of the switch to look for behind the brake pedal?!?!
Old Apr 3, 2014 | 10:46 AM
02RS25's Avatar
Google is your friend:
Old Apr 7, 2014 | 05:16 PM
MyWagon's Avatar
thanks
005STig
Aug 8, 2013 08:47 AM
Johnny02wrx
May 7, 2013 10:25 AM
mackeclipse
Mar 2, 2012 09:33 PM
wrx 03i
Aug 18, 2011 06:58 PM
kYLEMtnCRUZr
May 4, 2008 04:30 PM
