Wheel pattern/size
Car Info: Subaru WRX 08
Wheel pattern/size
Been lookin at some wheels, far as i know out bolt pattern is 5x100 right?
17x8? or 17x7.5? and offset? or does it matter much
Car Info: 2004 WRX Wagon
You should really do some researching. If it is the same as 04/05 bolt pattern, yes its 5x100. Offset can be around 48mm, and hub bore is 56.1mm.
Check out the wheels on wheeldude.com, they have the specs for all their wheels, learn yourself!
BY THE WAY THIS SITE IS AWESOME!! It will tell you every spec you need to know about your car http://www.cars101.com/impreza.html
Car Info: 08 WRX 5dr TBE, Perrin TMIC, VF52
I'm gonna order 18's for my car soon... but frankly I'd like a little more offset than stock... like a half inch or so. They're too tucked-under right now. The wheels I've found that I like have a 50mm offset (18x8) so I'm wondering how that compares to stock... meaning, I know stock is 17x7 with a 55mm offset, but an 18x8 with a 50mm offset... my best guess is they'd probably split the difference assuming there's clearance, so it'd stick out 1/2 inch. I dunno though.
Rob
Rob
Donnie_Doritos
Mar 30, 2008 10:57 AM
resident smurf
Mar 13, 2008 12:45 PM
