General Tech / How To's / Installations Technical discussions about the USDM 2008+ WRX and WRX STi.
oil change???
Old Nov 2, 2009 | 12:55 AM
perky808's Avatar
Car Info: past 06 WRX, present 08 STI
oil change for 08 sti???
this might be an off topic, since i pick up a 08 sti in the first week of may and i'm under 5k miles, what exact mileage for changing oil,and is there a specific oil and filter for sti? i know my old wrx i change every 3k, but not sure about the sti?.. thanks for checking...
Old Nov 3, 2009 | 12:44 AM
perky808's Avatar
bump, no help anyone?
Old Nov 3, 2009 | 09:00 AM
GirLDriven08STi's Avatar
Car Info: 2008 Aspen White STi
didn't they give you a maintenance manuel along with the owner's manuel when you bought the car? i think most of the guys here change oil at 3,000 miles which is what i'm going to be doing. as for the filter, check the machine they have by the oil filters in the stores. what oil i think is everyone's own opinion
Old Nov 3, 2009 | 04:26 PM
1SIKBRU's Avatar
Car Info: Audi Q5 aka "the old man wagon"
I went to full synthetic Mobil 1 and change every 5000 miles. The manual tells you to do it every 7500 miles with non-synthetic. The type of oil is kinda just up to you tho.
changing ur oil every 3k miles isn't necessary just so you know, unless you are tracking ur car all the time.
Old Nov 3, 2009 | 07:35 PM
thaSicness's Avatar
Car Info: Subaru WRX 08
i change mine no matter what every 3000.
Old Nov 3, 2009 | 11:11 PM
DemonPossessed's Avatar
Car Info: 05 wrx
I change mine every 3000 miles full synthetic castrol. oem subaru oil filter
Old Nov 4, 2009 | 09:06 AM
JaysImpreza's Avatar
Car Info: 09 WRB WRX GE Premium
I changed my oil at 1k, right after the break-in and then every 3k miles after that. im still using conventional oil.
Old Nov 4, 2009 | 09:31 AM
TSNWrX07's Avatar
Car Info: 07 WRX stage 2/ 05 Yamaha R6
I change mine roughly in the 3k-5k range
Old Nov 4, 2009 | 09:39 AM
Sasco's Avatar
Car Info: Stage 2 '13 WRX hatch
I've heard bad things about mobil-1 in sti's. Like burning a quart of oil every 1,000 miles and things like that :x. Have you experienced this?
Old Nov 4, 2009 | 09:42 AM
cueballsi's Avatar
Car Info: 2002 WRX- MBP
Rotella 5-40 Synthetic; every 4500 miles
This is not my Analysis, but why I chose 4500 as a change point...
http://www.bobistheoilguy.com/forums...Number=1530681
I use NAPA Gold filters or BOSCH Filters.
Old Nov 4, 2009 | 09:45 AM
danielliez's Avatar
Car Info: The 4 Train
If you read the warranty and maintenance booklet that came with car it says to change the oil every 3750 miles. Because the car is turboed it is considered to be operated under rougher conditions (even if you're not tracking it), and therefore they specify that the oil be changed more often.
I think this is a relatively new thing because my dad's 2005 Legacy GT does not say that he has to change every 3750. However, if you ever have a warranty claim I'm sure it would make your life a whole lot easier if you can prove you followed the maintenance schedule to a T... and an oil change is an easy thing to do to cover your ***.
You can also sign up for www.mysubaru.com and it will remind you to perform all the maintenance stuff at the proper intervals.
Old Nov 4, 2009 | 11:58 AM
04caliwrx's Avatar
you have to change oil?
Old Nov 4, 2009 | 07:01 PM
1SIKBRU's Avatar
haven't had any problems, and I was running about 21lbs boost for the last few oil changes.
Old Nov 5, 2009 | 01:11 AM
perky808's Avatar
thanks for your help guys, thinking im going to change my oil soon...
Old Nov 5, 2009 | 10:41 AM
kwiksilverwrx's Avatar
Car Info: 2015 WRX Limited (sold 2009 WRX beast)
I just take mine to subie, $40 gets a check up, oil change and filter, and car wash
