General Tech / How To's / Installations Technical discussions about the USDM 2008+ WRX and WRX STi.
oil brands
Old Aug 26, 2013 | 01:47 AM
subiekid916's Avatar
Car Info: 2009 subaru impreza 2.5i
oil brands
I have a 2.5 n/a impreza amd was wondering what type of motor oil people recommend... I have been running royal purple 5w-30 but have seen things about rotella t6 5w-40 and was thinking about trying it out
don't hate on the N/A
Old Aug 26, 2013 | 07:28 AM
queeg9k's Avatar
I am no oil expert but my mechanic recommended motul 5w40 bit that is for a Turbo car.
Old Sep 27, 2013 | 06:19 PM
KenLyns's Avatar
Car Info: Impreza 2.5i NA
@subiekid916: the non-turbo engine is not hard on oil. Any name-brand 5W30 conventional oil will be fine. I have used Mobil 2000 and Castrol GTX so far depending on what's on sale. I change my oil every 6 months with a Bosch filter.
Old Sep 27, 2013 | 08:00 PM
WRX~Mike's Avatar
I love Rotella T6, however I am a WRX
Old Sep 27, 2013 | 10:04 PM
2L Monster's Avatar
moist amateur
Car Info: 2k4 WRB/WRX
+1 for Rotella
Old Sep 27, 2013 | 10:27 PM
ddavis's Avatar
Car Info: 04 wagon
Amsoil
Old Sep 27, 2013 | 10:44 PM
w0ng3r's Avatar
Car Info: 2011 WRX Sedan
amsoil 5w-30 for that na!
Old Sep 29, 2013 | 10:27 AM
JourdanWithaU's Avatar
I had poor results with Mobil 1 5w-30. I have been using Pento High Performance II 5W-40 and the car is running much better with it.
I also kind of drive the absolute **** out of my car. I've also recently done an oil analysis and it came back pretty good.
Old Oct 2, 2013 | 04:09 PM
04GG's Avatar
If in doubt, FLAT OUT
I did not have good results with Mobil 1 either in the WRX. I am running OEM Subaru synthetic with zero complaints.
Old Oct 2, 2013 | 05:14 PM
I will take a look at amsoil then... it was recommended that I dont run 5-40 by my mechanic so I wont... no rotella for me :-(
Old Oct 2, 2013 | 05:24 PM
Harry Maneuvers's Avatar
Car Info: 04 WRX Wagon, 06 Forester XT, 99 Legacy Sedan
Another vote for AMSoil 5W-30 here.
Old Oct 8, 2013 | 08:31 AM
blade369's Avatar
Car Info: o10 swp wrx
Amsoil, Rotella T6, Subaru synthetic, and Motul are all very good choices. There's also Redline 5w30. I'd stick with with the Subaru oil filter for the bypass pressure setting though. 5w30 is the recommended but 5w40 is stated as allowed in the manual I believe. Takes research to find what is a good oil. Mobil 1 is good but it's thermal breakdown isn't that great compared to Motul, Amsoil, and Redline. Folks go with T6 cause it works, oil analysis comes back good and it's cheap.
Old Oct 8, 2013 | 08:48 AM
Brfatal's Avatar
Technical Know-It-All
Car Info: '02 WRX + '15 WRX
It's a non-turbo. he can run basically whatever he wants. He doesn't need Rotella or Motul. Nor would Mobil 1 be bad on his car.
Old Oct 8, 2013 | 08:54 AM
blade369's Avatar
Oh wow, I'm sorry. I even read that and totally spaced out on the fact it's na. Then yea run anything you want. Everything I said is just too much than what your motor actually needs. Wouldn't hurt you but yea... :P
Old Oct 8, 2013 | 09:06 AM
Brfatal's Avatar
Most of the reasons we run stuff like Rotella and DON'T run Mobil 5w30 is related to how well the oils handle high heat. Turbo Subaru engines run much hotter than the n/a ones and can be somewhat more sensitive to oil choices. OP's car doesn't need anything special. As long as whatever he runs isn't really poor quality it doesn't matter what he picks.
