General Tech / How To's / Installations Technical discussions about the USDM 2008+ WRX and WRX STi.
Not compatible with VDC?
Old Aug 3, 2009 | 05:28 PM
ScoobySon's Avatar
Car Info: 2006 WRX STI
On some websites, i.e. japanparts.com, they have wheels listed and in the comments shows "Not VDC compliant."
Now, I know 08+ WRX's have VDC.
Do aftermarket rims jack up the VDC?
Does anyone have some good evidence to back this up. I can't find anything solid.
Thx!
Old Aug 4, 2009 | 04:43 PM
1SIKBRU's Avatar
Car Info: Audi Q5 aka "the old man wagon"
as far as I know, as long as your rims/tires are the same on all 4 corners then it shouldn't be a problem.
What I have noticed, I have different tires on the front from the rear. Everything was fine for months, but recently I tried locking the center diff.. It seemed fine until I got back home and was going to park, it started to lurch forward and then jerk around. I switched it back to "auto" and the car jumped and made a loud noise, then went normally. Since that I haven't changed any diff settings and have not experienced that again.
I'd be surprised if any wheels actually caused problems with the VDC, assuming all your tires are the same.
Old Aug 6, 2009 | 02:28 PM
ScoobySon's Avatar
it might have something to do with the offset of the wheels. The ones that said not for VDC was Enkei rims with offset in the 30~40 range. Tire rack seems not to care or notice, but japanparts does?
Old Aug 6, 2009 | 02:37 PM
1SIKBRU's Avatar
offset wouldn't make a difference in rotational speed, so won't hurt the diff.
maybe the rims come in a set thats set up staggered?
but that wouldn't make any sense having awd.
Old Aug 7, 2009 | 10:08 AM
ScoobySon's Avatar
Here, check them out...
http://www.japanparts.com/db/partsli...maker=&volkey=
Old Aug 7, 2009 | 03:18 PM
Daios's Avatar
Car Info: RIP: 2000 2.5RS Sedan, BRP Now: 08 WRB WRX Hatch
maybe they mean TPMS? The wheels I put on aren't compatible with the TPMS so I have a light on the dash telling me I have a flat tire.
Old Aug 9, 2009 | 11:28 PM
1SIKBRU's Avatar
It makes no sense. You should be fine with those wheels. As for the TPMS, I thought all wheels were compatible with the system, you just have to put the sensors in the wheels, otherwise you get the flat tire light.
Old Aug 19, 2009 | 09:44 PM
ScoobySon's Avatar
Looks like the burden of proof is on me.
EvoHunter
Nov 19, 2004 12:06 AM
madmann28
Aug 10, 2004 03:09 AM
mstash
Dec 18, 2003 08:36 PM
