General Tech / How To's / Installations Technical discussions about the USDM 2008+ WRX and WRX STi.
Newbie question.. r they gonna fit my 2008 2.5i
Old Sep 4, 2009 | 05:15 AM
jeff_2.5i's Avatar
Car Info: 08 2.5i
hi everyone, I just have a deal on a set of used weds SA90
but i'm not too sure if they are going to fit my car
rims: weds SA90
size: 17x8 offset 42 (of coz they are 5x100)
tires: 225/45/17
planning to lower my car for an inch after I buy the rims
anyone has the same setup ? any rubbing issue ??
by the way, the spec of stock rims are 16x6.5 offset 50
and tires are 205/55/16
plz help
thanks
Old Sep 4, 2009 | 05:40 AM
subi4justin's Avatar
Car Info: 2015 SWP WRX
yes you will be fine to put those onto your car
Old Sep 14, 2009 | 04:56 PM
ScoobySon's Avatar
Car Info: 2006 WRX STI
Friend just got a 2010 2.5i Impreza. Is anyone knowledgable about what suspension parts fit between the 2.5i and WRX.
I would like to give him my 21mm Front and 16mm rear sways.
Since its the same color, I now have a person I can trade hoods with once the FMI goes on. Yut Ughhhh...?
Old Sep 20, 2009 | 11:04 AM
ScoobySon's Avatar
bump
Old Sep 24, 2009 | 03:57 PM
ScoobySon's Avatar
OK, found out that the 2.5i's dont even have a rear sway.
Can someone confirm if there are holes in the wishbone or lower-A arm (whatever its called) where you could install endlinks, which would then mean you could install a sway.
Anyone, Jourdan?, can you peep underneath your car? Havent you wondered if a sway would mount, I for sure would like to know if I had a 2.5i.
Old Sep 29, 2009 | 08:32 PM
ScoobySon's Avatar
K, took a look underneath a 2010 2.5i and the Control arms have holes for endlinks to mount to.
So, all I need to get for my buddy is the endlinks, bushings and mounts.
twinturbozs
Oct 22, 2012 01:35 PM
Jebb209
Oct 6, 2010 02:56 PM
jeff_2.5i
Oct 1, 2009 12:43 AM
redenzo
Mar 12, 2004 09:43 PM
UU R X
Jul 7, 2003 09:12 PM
