General Tech / How To's / Installations Technical discussions about the USDM 2008+ WRX and WRX STi.
cobb accessport!!!
Old Jun 1, 2011 | 12:29 AM
GimmeTQ's Avatar
Car Info: 2011 Subaru WRX STI HB
cobb accessport!!!
i have a 2011 sti hatchback and just got my cobb ap. i'm trying to load a map but instead it erased my cars entire ecu, set off a few lights, and refuses to load squat. now i can't drive my car cause it's bogging out and feels like crap. it tell me to cycle the key after the car is on and when i turn the car off it won't let me turn it back on. now i can't start my car without the ap plugged in as well! what the eff man?! keeps telling me some error and telling me to check the plug connection which is FINE! aaahhhhhhh!!!!
Old Jun 1, 2011 | 01:30 AM
wongjonsilver's Avatar
Car Info: 2011 WRX base - SWP
ouch. You should still be able to load maps onto your Accessport from your Cobb's website from your computer via USB. At that point, you should then be able to reflash using the AP. (though, you might still want to have the stock ecu map, but maybe the dealership can help with that. After all, it is a brand new car. Maybe all they'll do is slap you on the wrist for it. Goodluck!
Old Jun 1, 2011 | 02:47 AM
AlanNgo7's Avatar
Car Info: STi 2008
man... never heard of that problem. Be sure to keep us updated and tell us what happened! Goodluck
Old Jun 1, 2011 | 11:33 AM
Imprezard's Avatar
Car Info: 2010 997.2 GT3
Did you plug in the green connectors (test connectors) under the passenger side dash? That is probably the plug connection it is referring to. Then you should load the maps, and your car doesnt need to be turned on, it needs to sit in the on position (right before you turn the key to turn on the car). Also turn off your radio, a/c and etc. when reflashing.
Old Jun 1, 2011 | 11:40 AM
VRT MBasile's Avatar
I know the first version of the AP was a power hog and many people had problems with it draining the battery and then not loading the map, not sure if the ver2 is like that (but your battery should be fine since its new).
Make sure all connections are good to go, and keep in mind that turning the car "to on" is not the same as cranking the engine.
srbaugust
15
Jun 2, 2013 02:02 AM
roninrider_9
Apr 6, 2012 11:33 AM
bigbobchamp
Hawaii Classifieds
Nov 23, 2009 05:26 PM
xoaox
Mar 1, 2005 05:02 PM
