What's this "FWD"...resistor...thing?
Old Nov 6, 2003 | 04:07 PM
Mat - 98 R/T's Avatar
Car Info: '98 Neon R/T
At the back of the engine bay, just behind the passenger strut tower, there's a little box with a label that says "FWD". What the heck is it (for)?
Old Nov 6, 2003 | 05:54 PM
whitelegacy98's Avatar
if I remember correctly its a fuse you can pull to disable AWD for towing purposes.
Old Nov 6, 2003 | 08:26 PM
selt129_smk's Avatar
Car Info: 99 2.5 rs
so its used for towin, that would explain alot, i pulled it out and tried lightin the wheels up , but didnt work, guess i know why now.
Old Nov 7, 2003 | 09:42 PM
Ah...thank you. Selt, what happened exactly? I would assume that a RWD car would have no problem spinning at least a little. Or did it ignore the pulled relay and start transferring power up front?
Old Nov 8, 2003 | 05:58 AM
Peaty's Avatar
Acutally it a place to install a fuse and it will disable the AWD and you will only have front wheel drive then. It's for when you get a flat. You are suposed to put a 15A (I think) fuse in. That way the difference in size of the spare won't mess up your differentials. For towing you need all the wheels off the ground or you will toast the diffs.
All this is in the owners manual.
Oh only automatics have this fuse not manual trannys.
Peaty
Old Nov 8, 2003 | 05:44 PM
Defiantguy's Avatar
Car Info: 2004 Subaru WRX
ya there is a place around here that dynos wrx's and other subarus by using a custom center differential to make the car's rwd. Its pretty interesting, I might do it. If you want more info their site is:
Tadddd
Mar 1, 2012 11:51 PM
sigma pi
Jul 7, 2006 08:23 AM
rau
Sep 8, 2005 06:11 PM
Two Wheel Fiend
Jul 8, 2003 08:21 AM
