top speed
Old Feb 3, 2004 | 03:32 PM
cabe's Avatar
Car Info: 99 subaru impreza 2.2L coupe
top speed
What's the top speed of a mostly stock '99 imreza 2.2L coupe? Thanks.
Old Feb 3, 2004 | 09:49 PM
whitelegacy98's Avatar
I'm not certain but I'm pretty sure 112
auto or manual?
Old Feb 4, 2004 | 08:41 AM
cabe's Avatar
My car is a 5 spd and has already been up to 112 without cutting off.
Old Feb 4, 2004 | 09:13 AM
yeah, Ive been over 115 in my legacy that supposedly has a 112 cut off but that is the official top speed I do believe this was a thread a few months ago in the legacy forum I think.
Old Feb 4, 2004 | 09:26 AM
cabe's Avatar
Hey thanks a lot. I know I could go over 112 in my car. Is there any way I can take the speed limiter out or the rpm limiter out? ECU maybe?
Old Feb 4, 2004 | 01:02 PM
Defiantguy's Avatar
Car Info: 2004 Subaru WRX
112 is the cutoff if you have an auto
Old Feb 4, 2004 | 04:05 PM
cabe's Avatar
my car is a 5spd, not an auto
Old Feb 5, 2004 | 09:16 AM
you can have the speed limiter removed
Defiant guy: what is the limit for a 5-speed?
Old Feb 5, 2004 | 09:52 AM
cabe's Avatar
how do i remove the speed limiter?
also, defiant guy, I have had my 5spd to 112 without it cutting off, coincidentally, thats also where i wussed out, but I'm sure it would go faster.
Old Feb 5, 2004 | 09:53 AM
cabe's Avatar
o yeah, my friend has a 98 legacy gt wagon (5spd) that he has had to 118 and it didnt cut.
Old Feb 6, 2004 | 12:23 AM
TeamDI_Subie's Avatar
Car Info: '04 STi Platinum Silver, 353hp/ 367ft-lb
I have installed the JC Sports Torque Chip, the short ram intake, and a Stromung exhaust and I have been able to run out of numbers on the speedo and on up to redline. My car has a final drive of 4.11 and so i'm guessing the top speed to be somewhere @ 130. The first versions of the chip eliminated the rev limiter but the newer version have the rev limiter in place. The stock engine dies off @ 5800 rpm. JC Sorts however is no longer in business....CRAPPY SERVICE AND TOO LONG TO SHIP ITEMS!!!!!! I'm pretty certain that scoobysport has a similar chip.
Old Feb 6, 2004 | 06:53 AM
cabe's Avatar
Where did you get the JC chip and how much was it? Was it hard to install? Also, my rpms cut off at 6200.
Old Feb 6, 2004 | 01:11 PM
JC Sports is no longer in business and supposedly into R&D only now. I believe Scoobysport has a similar chip and they even claim it to be an equal to the JC Sports chip. They even look identical in the photos. To install you'll need to know how to solder and use heat shrink tubing to complete the job nicely. The hardest part will actually be counting the pins on the 3 ECU plugs. JC Sports had the ECU plugs labeled wrong so I had to count the pins myself. The install took less than an hour.If you get the chip, you won't see any immediate change. The chip will learn your driving habits and adjust the ECU to your driving style and change the torque band there. However if you decide to change the driving style as well after being progarmmed in you simply disconnect the battery for @ 15 minutes and start all over again. To get the most out of the chip it is claimed that the learning on the chip takes @ 4-6 weeks to learn how you drive. Even though our cars redline at 6200, it's normally better to shift @ 5800. I'm sure you notice the car bog down just before redline. The stock cams just simply quit letting the car breath. Until we switch out cams for a set of Cobb cams we will have to deal with it and work around it.
Old Feb 6, 2004 | 01:23 PM
I found the website
http://www.subaruplanet.com/electronics.htm#torquechip
Hopefully this will get you on your way and turns out that it IS the same chip that JC Sports had/has.
Old Feb 6, 2004 | 02:45 PM
Bagin,DVS's Avatar
Car Info: silver 2.5 tr 2006MT wrx
i hit 120 in my rs and it did not cut off, it just seem to take for ever to get theree, and it just seem to get there and hover at 120.
