pro ECM chip 2.2L
Old Feb 9, 2004 | 07:35 PM
cabe's Avatar
Car Info: 99 subaru impreza 2.2L coupe
pro ECM chip 2.2L
hey guys,
i found a chip for my 2.2 that will take the speed limiter out. its called the proECM.com power chip pc3. its @ http://www.imprezacars.com/electroni...roecmpowerchip
check it out and tell me if it would be easy to install. THanks a lot.
cabe
Old Feb 9, 2004 | 07:43 PM
ImpSP's Avatar
Car Info: 1997 impreza L
I installed it on my car and it was very easy, just find a good ground. The instructions pictures are very helpful.
Old Feb 9, 2004 | 08:41 PM
TeamDI_Subie's Avatar
Car Info: '04 STi Platinum Silver, 353hp/ 367ft-lb
As we discussed earlier, go with the Torque Chip II it'll work better and its rated for more output. Installation should be the same on both.
Old Feb 10, 2004 | 12:33 PM
cabe's Avatar
Someone else said that most people prefer the proECM over the Torque chip. They also said that the Torque chip didn't show any enhancements on the DYNO. I guess they do pretty much the same thing, just one adds more torque supposedly.
Old Feb 10, 2004 | 04:58 PM
The Torque Chip was designed to alter the torque curve and not really meant to add more hp. I have a copy of the dyno test sheet here in a folder from JC Sports when it was in open ot the public. When I do buy engine parts, I only buy parts that have a dyno sheet to show e something other than a claimed number. Even at that level it all depends on the dyno,weather,altitude,settings,etc. . Just use your own best judgement and choose what you think will work best for your car and your driving.
Old Feb 10, 2004 | 07:23 PM
cabe's Avatar
Would more torque give you better acceleration?
Old Feb 18, 2004 | 07:31 PM
cabe's Avatar
did you install it yourself? i have no experience doing this and dont even know where the ecu is. what would you recommend?
Old Feb 18, 2004 | 10:06 PM
ImpSP's Avatar
The instructions should be enough. But if they aren't: your ecu is under the carpet where a front passengers feet would be. The instructions will tell you which wires to cut (about 2 or 3). I believe connectors are provided so you don't have to solder. Like I said before make sure you find a good ground. That's it .
Old Feb 19, 2004 | 07:53 PM
Defiantguy's Avatar
Car Info: 2004 Subaru WRX
its not too bad as long as you use a wire ground and not a bolt. I had issues with that but I got it figured out eventually.
Old Feb 20, 2004 | 08:27 PM
Kostamojen's Avatar
NASIOC Slut
Since this isnt NASIOC (where anyone who talks trash about the torque chip or the proecm gets shut down fast) let me state something...
AVOID BOTH OF THESE!!!
They do jack. Usually the ECU just learns around them. I have yet to see actual gains from either chip. Every single person I know of from nasioc who has had one for like a year or two sells them because they do jack. And several people have had issues where the chip has caused the engine to overheat (because it effects the sensor that deals with engine heat)
Spend the money elsewhere.
Old Feb 21, 2004 | 08:41 AM
cabe's Avatar
Is there any other way to remove my speed limiter? Why hasn't anyone else said anything about these problems?
