O2 sensor
Old Jan 2, 2004 | 08:03 AM
SubySal's Avatar
Car Info: 2004 2.5RS pacifica blue with black Tarmacs
I would. The only time an O2 sensor doesn't influence the air/fuel mixture is a WOT so if it is not working correctly it can excessively lean out or richen the mixture causing overheating or a blown engine. To prevent this car companies put a "safe mode" or "limp mode" in the ECU which means that when the CEL comes on it will run at preset fuel maps till the problem is fixed and the code cleared. This mode means the car will not run at optimal levels which usually means spuratic idle, loss of power, and decreased gas mileage. The amount of mileage usually determines if it needs to be replaced. OE units tend to last around 60,000 miles on average because heat and electronics don't work very well together. You could call a dealer or email SOA for more specific info.
-Sal
Old Jan 2, 2004 | 02:23 PM
Re: O2 sensor
Originally posted by sausagemahoney
Last month I got a CEL. I checked it out and It turned out to be my O2 sensor. I got rid of the CEL, but not the sensor. I am about to replace it before a long road trip, but do I really need to? How do I know if it really needs to be replaced?
Do you have mods? What's your mileage? What car is this for?
polishwrex
Jan 7, 2009 12:25 PM
Peaty
May 30, 2008 09:58 AM
NorCalDC5
Jul 22, 2007 11:44 AM
Wildblitz1337
Feb 18, 2006 06:35 PM
