nitrous
Old May 9, 2003 | 04:18 PM
Imprezzive's Avatar
Car Info: impreza 2.5rs
nitrous
hey whats up , i just wanted to know how reliable is nitrous on a 2.5rs motor.
Old May 9, 2003 | 05:22 PM
It depends. If you (or the shop you have design it for you) are knowledgable, you can make a 50 shot work fine. But even a 25 shot can blow your motor if it isn't properly tuned. At a minimum, you need a wet kit, fuel pressure riser, and AFC. Better still would be real engine management. The short answer is, if you just buy a kit, bolt it on and go, you'll probably break a piston or rod, or blow your head gasket.
Old May 9, 2003 | 05:30 PM
Imprezzive's Avatar
i have the safc which still has to be installed other then that, the fuel pressure riser, how much is that, and what does that do
Old May 10, 2003 | 07:56 PM
The fuel pressure riser... raises fuel pressure.
Other than that, make sure you get a 'wet' kit. This means it adds extra fuel with the nitrous to prevent it from running lean. Better still, find a good shop with a lot of experience to tune it for you if you aren't comfortable with it.
NotoriousWRX
Feb 4, 2003 05:32 PM
Burninwrx
Jan 19, 2003 01:56 AM
optimalrage
19
Dec 24, 2002 09:42 PM
DoctorNick
14
Nov 27, 2002 03:28 PM
Imprezinator
Nov 27, 2002 10:03 AM
