Intakes: What's the difference, really?
Old Dec 19, 2003 | 04:56 PM
stg2lgcy00's Avatar
Most of the intakes with the cone filter on the end just suck hot air from the engine compartement, which isn't good. For example Cobb's design using the PRM filter pulls cold air directly from the wheel well, which is much cooler.
Old Dec 19, 2003 | 10:59 PM
DetailAddict's Avatar
Former Vendor
Car Info: Evo X
sorry, i am too lazy to search. but i remember seeing someone actually did a test (measurement) on different intakes including stock air box. The result was that stock box wasn't much hotter than your after market. It was measuring at different speed (different air flow). Do a search on NASIOC and you should be able to find something. it was a VERY detail report. good luck.
Old Dec 29, 2003 | 11:47 AM
KmanRuffian's Avatar
Car Info: 2002 White WRX Wagon (WWW)
We've been through the intake thing already several times, search for the threads. Bottom line is if you are looking to gain performance, look elsewhere. If you want to hear the turbo better hack up (snorkus removal) the stock one. Unless you have a bigger turbo and are making big power, don't get an aftermarket intake. There are problems with CEL's and such that just do not make it worth it.
Edit: And we have also discussed why CAI's have little or no effect with a turbo car. Well some bad effects possibly, but certainly no good ones. Spend your money elsewhere man.
Old Dec 29, 2003 | 05:27 PM
Kman, this is the NA forum. Intakes actually do have a positive affect on MAP sensor based Scoobies, although a small one. I personally have a GanzFlow I got used. It makes a little more power and a lot more noise.
Old Dec 29, 2003 | 08:30 PM
Kostamojen's Avatar
NASIOC Slut
Yes they make a huge difference. Shows up on dynos. The cobb so far is the best for pure performace, followed by the injen and custom made throttle body intakes. The J-bend pipes with cone filters attached tend to not do alot though, and rob the car of some low end. This has been discussed before in great detail (mostly on nasioc, but still here as well)
Old Dec 29, 2003 | 10:06 PM
crap, my bad, I didn't realize this was the NA forum. My bad, I thought it was the turbo forum! Sorry!
Old Dec 29, 2003 | 11:27 PM
No worries.
Krinkov
Mar 9, 2011 09:00 AM
MPOWERD
Oct 1, 2004 02:41 PM
RussB
Jun 11, 2004 04:04 PM
OakosAutomotive
Vendor Group Buys/Specials
Nov 14, 2003 02:53 PM
LUV2XLR8
Oct 7, 2003 06:26 PM
