I want more power ....
Old Jan 24, 2006 | 05:09 PM
EJ_20's Avatar
Car Info: Impreza 2.0
Unhappy I want more power ....
okay guys,
I have a 03 impreza with 2.0 N/A engine (( EJ20 with 120Hp )), and I want more power so what should I do??
is it possible to bore the engine block and make it 2500cc (( or +2500cc )), if so then would these fit on my EJ20 crankshaft and rods.
http://www.rallitek.com/products.asp...Y&HB=&ACC=&SP=
Old Jan 26, 2006 | 04:24 PM
AWDimprezaL's Avatar
its not worth it, import a usdm SOHC 2.5 block and swap out your old anemic 2.0
Old Jan 26, 2006 | 11:11 PM
EJ_20's Avatar
Unhappy
I know that would be much easier but that will cost me alot of money just for the shipping (( I live in the middle east )) and it really hard to find a 2.5 engine cuz they are very rare in here, so I guess that bore the engine from 2.0 to 2.5 is the easest/cheapest way for more power, but all I need to know is if it's possible on a 2.0 engine!!
Old Jan 26, 2006 | 11:36 PM
VIBEELEVEN's Avatar
Car Info: 03 WRX
No, it would be cheaper and easier to just swap in any of the 2.5l engines. You may want to stick to n/a, since your car wasn't origionally equipped with a turbo engine, you will run into alot of problems with wiring and harnesses.
Check out the kits COBB tuning makes for the USDM n/a engines....
http://cobbtuning.com/impreza/powerpackages.html
Old Jan 26, 2006 | 11:48 PM
sdh's Avatar
sdh
Car Info: 2005 2.5 RS Impreza Wagon
more power
(1) the n/a engines have different blocks and heads than the turbo motors, so it is risky to turbo the n/a motors. the turbo engines are more reinforced and have closed deck heads.
(2) get a 2.5 single cam engine or get a new car.
(3) see # 2 above again
Old Jan 27, 2006 | 12:09 AM
VRT MBasile's Avatar
what impreza has an N/A EJ20??
Old Jan 27, 2006 | 12:14 AM
VIBEELEVEN's Avatar
Car Info: 03 WRX
He's in the middle east.
What country are you in? Are you in the military?
Old Jan 27, 2006 | 10:11 PM
EJ_20's Avatar
I'm from U.A.E ( Dubai ) and I don't work in the military
Old Feb 1, 2006 | 01:55 PM
EJ_20's Avatar
Question
guys.... I need to know cuz if possible I will buy the 2.5 pistons and rings and bore my 2.0 engine to make it 2.5
CaliSuby
Oct 20, 2010 03:29 PM
Speed Element
Engine and Drivetrain
May 13, 2010 11:10 AM
gpatmac
Dec 24, 2003 01:41 AM
