HELP!!! Somethings burning!!!
Old Dec 5, 2007 | 02:55 PM
milom80's Avatar
Car Info: impreza wagon!!!
I have a 98' Impreza wagon. All is well....except.... everytime I run it, then shut it off theres a terrible burnt rubber smell. Any crazy ideas. Everything runs fine and it has all new belts, minus timing. No other problems. Please help!!!
Old Dec 5, 2007 | 03:37 PM
ipozestu's Avatar
Car Info: Broken Subarus
Burnt Rubber smell; could it be burning oil? Does it smell/smoke when you stop for a light? Auto or manual transmission? Check underneath the car see if it's wet with oil. Might have a transmission oil leak. I had a problem with my Lagacy. One of the hoses that went to the tranny cooler dripped on my exhaust pipe. If you find the underside of the car if covered in oil the best thing to do is soak everything with degreaser take it to a coin wash and spray the crap out of it. wipe it down then drive it around for a couple days and see if you can spot the leak. It should be much easier when everything is clean.
Old Dec 5, 2007 | 03:58 PM
milom80's Avatar
very well could be, I had to replace a oil pressure sending unit and its been doing it eversince that. It used to smoke BAD but not anymore. There is also oil on the underside of the motor all over everything, but i havent noticed a drop in fulid levels?! wtf...great advice thank you!!!
Old Dec 5, 2007 | 08:26 PM
ipozestu's Avatar
The sending unit should be reinstalled with a crush washer. Otherwise they will leak like crazy. Get things cleaned up and start looking for your leak.
Old Dec 6, 2007 | 07:43 AM
AWDimprezaL's Avatar
according to my parts catalog, the oil pressure sender does not have a crush gasket
Old Dec 6, 2007 | 08:52 AM
ipozestu's Avatar
It;s not as much a crush washer as it is an aluminum gasket.
Here you go,
https://www.subarugenuineparts.com/p...roducts_id=961
Old Dec 6, 2007 | 11:23 AM
no no no, he is talking about the oil pressure sender, its ON TOP of the block, i work at a subaru dealer in parts, i assure you there is no crush washer for the oil pressure sender.
Old Dec 6, 2007 | 11:28 AM
see? my parts catalog
Old Dec 6, 2007 | 11:55 AM
ipozestu's Avatar
If you work in the parts dept. you should know that the oil pressure sender screws into a gallery plug which screws into the block. Between the gallery plug and the block there is a crush washer. Have a nice day.
It'd be nice if they had people in the parts dept. who actually worked on these motors.
Old Dec 6, 2007 | 01:16 PM
sorry but i DO work on them, there is no need to unscrew that plug to to an OPS ever
Old Dec 6, 2007 | 02:12 PM
ipozestu's Avatar
Edited: for sake of keeping peace
Old Dec 6, 2007 | 02:17 PM
milom80's Avatar
Just attempting to get some help not start a fight... subaru owners should be a band of brothers not against each other.... I thank you both
Old Feb 7, 2009 | 09:15 PM
scobytech24's Avatar
Car Info: 98 subaru impreza
brothers ive worked on lot , stop. is the smell from driving in the snow ? is it after you rally the poo out of it? WHATS GOING ON TO CAUSE THE ISSUE. let me know
Old Feb 7, 2009 | 09:29 PM
offseasonmvp's Avatar
Car Info: WRB '08 WRX 5 Door
mine alwayz smells like clutch burn when i dont baby it. mines an 08 wrx tho so carry on
Old Feb 7, 2009 | 09:44 PM
Irrational X's Avatar
plays well with others
Car Info: your mother crazy
bumping 14 month old threads makes jesus cry.
5 bucks says he had a blown CB boot
