HELP! Cooling fan problem.
I noticed that only the driver side cooling fan is coming on while the car is running. Do I need to replace the passenger side fan or could it just be a fuse or connection? What should I look for?
:lol:...the other fan is for the ac...turn it on and youll see
OHMYGOSH! HAHAHAHA! That was the dumpest question I could ask.. Thanks for the answer.
have you checked to make sure the plug is connected in properly? if it does appear to be, unplug it, clean it with a soft wire brush, throw on some dielectric grease, then plug it back in.
