Cause of Overheating?
Old May 13, 2010 | 04:12 PM
salvator_rizzo's Avatar
I have a 2003 OBS.
Previous problem- I was running a rebuilt 98 ej25D block with thick headgaskets and 2003 SOHC heads and all sohc wiring exhaust, basically everything else. However, that engine kept overheating, so we assumed that the headgaskets were not thick enough (compression too high, causing engine to overheat).
I gave up with that setup, just swapped in an ej251 with 80k miles on it, used the 2003 intake manifold and everything etc.
took it for a quick test drive today, the coolant started to back up and I could hear it bubbling in the top radiator hose. The overflow tank had more coolant than I put in it when I filled the radiator.
Also, the car has a brand new coolant temp sensor. The thermostat looked pretty good, I have a new one i could put in if neccesary, but i dont think thats the cause
another thing to note -
I changed the oil/filter last night, there was no coolant in the oil so im confident its not blown HGs's
Could it be possible that the radiator is bad? The problem keeps happening and this is a completely different engine
Old May 13, 2010 | 05:34 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
This 80k motor, did you replace the head gaskets before installing it?
Old May 13, 2010 | 07:35 PM
i did not. Probably would have been a good idea though
Old May 13, 2010 | 09:19 PM
glenspen's Avatar
Car Info: 05 WRX
over the last few years I've noticed that Paul has ninja skills for diagnosing problems...whenever somebody posts a problem he normally gets it right with just a few questions....
Old May 13, 2010 | 09:32 PM
Are there ANY leaks of coolant? Either in the engine bay or under the car/ground?
Old May 14, 2010 | 05:31 AM
absolutely no leaks that ive been able to find. Ive left the car in the garage over night and there was nothing under the car
Old May 14, 2010 | 08:58 AM
Sounds like you should check the head gaskets like Paul said
Old May 15, 2010 | 10:14 AM
strider327's Avatar
Car Info: 2005 WRX
Sounds like a HG to me. Or it could be your theromstat or not burping it properly.
Old May 15, 2010 | 12:49 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Are you sure you're bleeding the coolant system fully?
-- Ed
Old May 17, 2010 | 09:02 AM
I'll replace the thermo and see what happens. thats easy enough
I definitely bled the system completely. that was one of the first things I tried
Old May 17, 2010 | 09:24 AM
MonsterGC's Avatar
Car Info: 2000 2.5rs
burping it correctly?
Old May 17, 2010 | 11:14 AM
ipozestu's Avatar
Car Info: Broken Subarus
Blown Head gasket does not mean there's gonna be water in the oil. Cylinder pressure makes its way into the water jacket displaces the water through the overflow. Eventually no cooling. Seen in on a few separate occasions.
Old May 17, 2010 | 04:08 PM
I burped/bled it properly I believe. It looked like all the air was out and there was no more coolant that could go in.
^ this might be true, and i rather it wasnt the case lol. But we'll see.
I called two subaru shops around (Fine Line/PJ's foreign Auto) that ive been talking to a ton and they think its possible that it could be the radiator. I pulled it out this morning and brought it to a good radiator shop suggested by Pj's for a flow test. They checked it out and they said they think its the cause of the overheating, it doesnt have good flow or whatever. They are going to clear it out/fix it and then ill throw it back in the car tomorrow and see what happens.
Old May 17, 2010 | 04:09 PM
Hope that works
Old May 17, 2010 | 04:48 PM
iClub Silver Vendor
How hot did the gauge go when the engine overheated?
You may still need to repair the head gaskets after the radiator returns.
Top
