borla header and OEM oil cooler
Old Jul 27, 2003 | 11:45 AM
Kay95's Avatar
well i have a 95 L 1.8 and i plan on geting a borla header and subaru liquid to oil cooler but i looked at pictures of them installed and they look to be in the way of each other
the reason i want to get a oil cooler is because i drive very very hard (think 4K-6K in third for a quarter mile at a time or more because this little 1.8 arrg) and the last time time i changed oil the frition material on the bottom of my fram sureguard oil filt must have been heated enough that it got hard and bubbled that flaked off when touched
i know someone on this board uses a turbo kit and the oem oiler cooler with the borlas and i want to know if it fit as is or if cutting and welding are order
Old Jul 28, 2003 | 01:30 PM
Kay95's Avatar
how much clearance was there?
do you think wrapping would be good idea too?
Old Jul 29, 2003 | 01:44 PM
Kay95's Avatar
do you have any pics?
and what ss line are you talking about the line from the thermo housing to the in side of the sandwich adaptor?
Old Aug 4, 2003 | 01:30 PM
Kay95's Avatar
i got to thinking about this and the coolant coming from the radi is about 150 to 170 degrees(hand on bottom hose) and liquid to liquid has better heat transfer than liquid to air but a really big core whould do a much better job than the oem but then were do you put it? in front of the radi or take the fender off and sit it there
i'll ask at scoobymods exactly how they have theres
but thanks alot for the input
Old Aug 20, 2003 | 12:26 PM
rau's Avatar
rau
Something Custom
where did u find your Borla header for a 1.8?
Old Aug 20, 2003 | 02:25 PM
Kay95's Avatar
all EJ engines with dual exhaust ports fit borla
so that means it fits all 2.5, 1.8 and some 2.2(all til 97)
just look for ones that fit the 2.5
to get you started
http://www.rallitek.com/ (cheapest i think)
mystilexzero
Apr 18, 2015 03:37 AM
RAWeiss
Nov 29, 2014 08:11 PM
blaznc
Subaru OEM Parts For Sale
Nov 15, 2006 09:50 AM
depdivr
Sep 29, 2005 10:52 PM
mj
Dec 10, 2003 10:21 AM
