borla header ground clearance
Old Apr 19, 2004 | 04:24 PM
bheinz57's Avatar
Car Info: '02 OBS '03 Baja
I don't think it's that much different than stock-you may be a tad lower, but you also loose all the heat shield parts from the old header. Brian
Old Apr 19, 2004 | 04:56 PM
Kostamojen's Avatar
NASIOC Slut
They are lower. Not much, but the front is definatly lower as the borlas go along the front of the engine instead of straight back. You can see the difference when you look under the car.
Old Apr 19, 2004 | 10:15 PM
Daios's Avatar
Car Info: RIP: 2000 2.5RS Sedan, BRP Now: 08 WRB WRX Hatch
is this low enough? didn't really check before and after i installed it
I think i lost a little bit of low end but can't tell... def increased mid/high end thought or it could be just in my head while on the freeway has a nice sound for sure though
Old Apr 29, 2004 | 11:36 PM
Daios's Avatar
hmm... never really thought about that one haha...
but doesn't seem too hard to get to it... just watch out for hot headers since they can be easily touched... i don't think its too much of a problem since i use a socket for the oil filter with a long extension
now that i think of it... i wonder how hot that filter gets now while driving o_0
Old May 1, 2004 | 10:14 PM
Daios's Avatar
i was thinking of getting the oil cooler at some point but not sure now how close the filter will be to the headers... think it would fit...
but anyways i use the same filters as from the dealer
Old May 2, 2004 | 10:15 AM
bheinz57's Avatar
The oil filter is real close-close enough to burn the black grabbing crap on a fram...Not bad enough to put a damper on oil changes, still plenty of room to take off/put on. Brian
smyamaha
Aug 6, 2008 09:32 PM
bjamerican
Apr 8, 2008 04:14 PM
MCGRIFF
Aug 2, 2005 01:06 PM
lin_tp2
Feb 18, 2005 02:49 PM
mj
Dec 10, 2003 10:21 AM
