Backpressure stuff
Old Aug 25, 2004 | 11:15 AM
ride4life32's Avatar
pressure stuff
ive got a 99 RS and its got an AEM intake and ive got magnacore wires with bosch plugs, but you may be right about the coil since i have not checked that yet
thanx man
Old Aug 25, 2004 | 11:51 AM
The intake is not helping either. The MAF sensor is sensitive to changes and I would be willing to bet the car is running quite rich at the stumbling points.
Old Aug 25, 2004 | 02:43 PM
jdepould's Avatar
Car Info: 1990 thing
Originally Posted by BAN SUVS
No, he was saying that a certain amount of backpressure is good. But if your car still has stock headers and the stock cats, then the catback doesn't do anything but make noise really. What year is your car and what intake do you have? That's the more likely culprit, barring a mechanical issue like bad wires or coils.
that's exactly the type of thinking I'm trying to dispell. Backpressure is bad, period. When you open up the exhaust too much, you lose exhaust velocity, and lose power, which is entirely separate from backpressure.
Old Aug 25, 2004 | 03:22 PM
yes you are very right when it starts to stumble or even when it doesnt at that point i can see teh black cloud behind me telling me that it is a very rich burn. what suggestions if any do you guys have that could fix my problem thanx
ride4life32
Old Aug 25, 2004 | 03:39 PM
Put your stock intake back on. See if that gets rid of the issue.
Old Aug 25, 2004 | 04:02 PM
meilers's Avatar
What you are talking about is technically called "scavenging," correct? The idea is to have enough pressure to create pockets of lower pressure in the exhaust pipe that help to pull the gases through the pipe and out the end. Too large of a diameter of pipe allows for turbulence, which is exhaust gases flowing over themselves and not straight out the pipe. Is this the idea?
Old Aug 25, 2004 | 04:17 PM
In a normally aspirated car, I believe that's correct meileres, although I've never studied the thermodynamics to find out for sure. In a turbo car, however, exhaust gas velocity is what drives the turbine, so any loss of that through larger manifold runners and uppipe results in lower boost.
Old Aug 25, 2004 | 10:20 PM
jdepould's Avatar
bingo
Old Aug 26, 2004 | 09:09 PM
it helped a little bit but do you think if i got like an aftermarket MAF sensor or like an ECU jet do you think that could do the trick.
Old Aug 27, 2004 | 07:26 PM
kitsune713's Avatar
Car Info: '06 RBP Impreza 2.5i
I agree with your post, although I would say that the ideal size of an NA 4 cylinder exhaust varies with the displacement of the motor. 2.25" works GREAT on EJ25s, and 2.5" is good too. On a ~2.0 liter motor, 2" is probably best.
What about an EJ22?
Old Aug 28, 2004 | 02:01 AM
Not much experience with that motor myself but I would guess 2.25" would be best.
Old Aug 28, 2004 | 12:01 PM
kitsune713's Avatar
I thought so... thanks!
Old Aug 28, 2004 | 10:49 PM
awns729's Avatar
Car Info: want a WRX
2'' wouldnt be bad either, would it? less top end but better low and mid range torque...
Old Aug 29, 2004 | 01:04 AM
Yep pretty much.
Old Sep 2, 2004 | 03:34 PM
Myxalplyx's Avatar
We can't make the generalization of thinking that certain engine sizes go with certain exhaust piping size. It all depends on the air flow capacity of that engine. A Honda S2000 probably wouldn't do best with a 2" exhaust.
Piping size doesn't matter on a turbocharged car since exhaust velocity isn't an issue since the header runs into the turbo itself (Uppipe). The only piping size you'd be concerned with here is the uppipe.
