94 octane gas (for n/a EJ25)
Old Jul 13, 2004 | 07:46 PM
2.5RS's Avatar
i just start put in 94 octane to my 2.5rs. Some people say is good and some say is bad???? but for me i think it run smoother than before. and i heard not all the car could use 94oct???? could any of you guys, give me an answer. THanks
Old Jul 14, 2004 | 02:13 PM
nic3krnnamja83's Avatar
nothing wrong in running 94 except the price
Old Jul 14, 2004 | 02:21 PM
RoadSpike's Avatar
According to past threads running higher octane than your mapping is set for will put carbon deposits in the system.
Old Jul 17, 2004 | 02:24 PM
Myxalplyx's Avatar
It'll appear to run smoother, yes. I noticed this in my 1997 Outback Sport as well. You are probably actually losing power. How do I know? I tested it at the dragstrip in both my Subarus. Even went as far as putting in 100 octane from the track. Throttle response seemed to improve and it ran much smoother BUT my 1/4 mile times were slower in both cases (Subaru XT6 and OBS).
If you want to take advantage of higher octane, don't go so high. Since stock is 87, go with 89 octane. It'll enable your ECU to bump up timing slightly so you can take advantage of it. Our car's timing is pretty aggressive. How do I know? I checked it out with a Pocketlogger on my Palm Pilot. How much was timing bumped up before and after using higher octane. I can not remember. Maybe 4-5 degrees or so. However, my OBS seems to run best at 89 octane rather than 87. 89 octane again will enable your ECU to run more advanced timing. 87 octane will probably experience some pinging in some situations (Very hot day, high load from extra people, etc) so timing will be pulled back some.
I'd only run 91-92 octane if your stock compression ratio was more than 10 (Like some of the later Imprezas) for the same reason stated above.
Don't take my word for it. Test the 87 octane vs 89 octane at a dragstrip sometime if you get a chance. Try to make sure the testing is in similar weather conditions (no more than 15 degress difference in temp). You'll see what I mean. Good luck!
kidatari
Sep 9, 2004 12:22 AM
rota wheels wrx
Sep 6, 2004 04:57 AM
Need4speed
Mar 29, 2004 11:31 PM
