2.5 rs ecu reflashes?
Old Jan 9, 2011 | 10:37 PM
2.5aru's Avatar
Car Info: 2.5 white
I have a 03 Subaru Impreza 2.5RS. I want to do something for the ECU. ive checked out cobb tunning and they have some package deals for my car. Is this a good idea.
is there alot of horsepower to be gained from this?
What do they change exactly?
will i need bigger injectors?
if a had my cams shaved 1000profile afterward, would i have to reflash again?
i haven't seen much ecu n/a tuning threads
will i get a get a backup of my original ECU. Is there a place where I can get that done?
i will be doing a major service to my car in the near future belts water pump Valve Cover and Spark Plug Gasket, new spark plugs, valve adjustment?
should i change/replace anything while so much is off my engine?
Thank you! kill me softly
Old Jan 10, 2011 | 11:30 AM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
keep it how it is..its too much to build a N/A. Any money you put into it, it will still be slower than a turboed car.. plus you'll save gas and at least you have the ability to out live a turboed car haha..
Old Jan 10, 2011 | 12:06 PM
2.5aru's Avatar
Car Info: 2.5 white
Ya it gets pricy when the engine starts coming out everyother weeklol. Just wondering if a place like WORKS offers a quick tune for n/a. 168 h/p leaves civics molesting me on the road. After weighing a swap out with n/a tuning, the swap still will cost uppwards of 4to5 grand for a (non wrench monkey like myself). The shear magnitude of replacing engine, tranny, exhaust, is too much for my first tuned car.
And turboing a 2.5 looks like that will result in 2 months of fun shortly fallowed by tranny failure.
Come on someone has cranked these single cam airplane engines to higher HP. Without strapping sudden death to my stock block.
Old Jan 10, 2011 | 02:18 PM
bobbyjimmy's Avatar
Car Info: A Car
http://store.crawfordperformance.com...categories/249
Click on the different levels (SRS10, SRS19, SRS20, SRS30 etc) for what you need and a guesstimate on how much *power* you'll get from it.
Also, try a search on RS25.com
Old Jan 10, 2011 | 08:42 PM
2.5aru's Avatar
Car Info: 2.5 white
Thanks for the advice ill look into Crawford and yes active on rs25. I'm not expecting any more then a quick 15 to the ground powerwise
Old Jan 10, 2011 | 09:12 PM
2.5aru's Avatar
Car Info: 2.5 white
So Crawford makes the rs reflshes and the only category. Without getting new heads and running a catless exhaust is the srs-10. What is the difference between the srs-10 and the srs-10 + core. I guess my question is what's the core? 5-10 HP is the gain as well
KOSTI
May 2, 2008 12:47 AM
ImprezaRSX
Aug 7, 2006 09:37 AM
GottaREX
Wanted
Feb 22, 2004 07:13 PM
IS300
Nov 16, 2003 07:56 PM
