2.2 automatic owners
i have a 98 l and did the grounding mod and i now idle at 200 rpms yes this is correct. I still have a very smooth idle but im concerned that it might not be as responsive as it is supposed to be . Should i have a higher idle? What do you idle at?
No way a 200 rpm idle would be smooth. Use something else to determine the true Idle speed. I suspect something about the grounding kit or install weakened the tach signal.
Car Info: 2003 subaru forester xs
i guess the only way to diagnose this is to unhook everything and see what happens.
this may not do anything but have u tried resetting the ecu? it's a long shot, but who knows?
Car Info: 1998 Subaru Impreza L 2.2
low idle
Maybe the problem isn't the grounding mod and the problem just occurred simultaneously with your grounding mod. Don't be offended, but are all the grounds tight?
Other options could be a vacuum leak, IAC malfunction, fuel pump not sending enough fuel, dirty throttle body, air filter.
Take the grounding mod off and see if your problems are fixed. Good luck.
-Charles-
-Charles-
hey dude its me, just curious but r u sure its 200? there's 0 on yur tach and then the next line is 500 i think. if u want i'm usually done with my fuels and emissions class by like 2 if u wana gimme a call and i can take a look at it with you. my cell is 9787294140 and if it helps my class right now is over in leavitt and smith's lab in the erc next to the atc. later man
