1997 Impreza OBS 100k Service
Old Dec 31, 2012 | 07:39 AM
HappyAsAClam's Avatar
Car Info: 1997 Subaru Impreza OBS
Just got the car it has 102k on it and I want to get it serviced. Im a complete Subaru newbie and need suggestions on parts that typically need replacing at this point
Old Jan 24, 2013 | 02:18 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
You'll need to replace the timing belt, tensioner, idler pulleys, water pump, thermostat, and coolant. You also want to check the last time you've done the transmission and diff fluids, engine oil, and spark plugs.
-- Ed
Old Jan 24, 2013 | 02:26 PM
02RS25's Avatar
-- Ed
+1
i recommend that you DO NOT pick up parts from oreilly or autozone etc. i replaced thermostat when my original got stuck open. replaced it with oreilly thermo and coolant. blew passenger headgasket 1k miles later. (yes i intalled it correctly) spoke with suby techs and appareantly with our aluminum crankcase, using the correct coolant and accessories is crucial. GL!
Old Dec 9, 2013 | 03:50 PM
bobgengeskahn's Avatar
Car Info: 2006 Subaru OBS SE
This has been a generally invaluable resource for me in researching and recently buying my 06 OBS.
Subaru 2007 Impreza Outback Sport, Special Edition SE, 2.5i sedan and sport wagon, WRX, STi, options, price, photos and more
Edit:
Totally mis-read your year (good find with that mileage BTW). I did find this that might help you, they appear to be down at the moment, but they have user manuals in PDF that should include a maintenance schedule for your car: http://www.subaruoutback.org/forums/...oad-links.html
Old Dec 12, 2013 | 10:42 AM
04GG's Avatar
If in doubt, FLAT OUT
-- Ed
As mentioned, if they haven't been done, I'd recommend just doing all the fluids including the brake fluid. Check radiator hoses when doing the coolant, replace fuel filter, and check the shocks. Those are the things encountered with my 97 when I picked it up. It currently has over 160K more miles than yours
HappyAsAClam
Dec 30, 2012 12:28 AM
impreza_rf
Oct 14, 2011 10:18 AM
Kevin M
Jun 25, 2007 09:12 PM
ant927
Jan 20, 2006 10:04 PM
devo
Cars For Sale
Nov 9, 2005 11:47 PM
