will a cat-back and up-pipe make a TBE or is it cat-back and downpipe?
Old Dec 28, 2004 | 08:57 PM
Steven@Coach's Avatar
Car Info: 2011 WRX Hatchie
TBE is downpipe+catback. And from what I've heard u should port wastegate on the STI if adding a TBE.
Old Dec 29, 2004 | 01:30 AM
Usually, though not 100% of the time, the boost cut problem stems from putting catless TBEs on the older '04s with the P17 exhaust housing. It can still happen if you have a cat, or if you have the larger P18 housing (which effectively means your VF39 is a VF34) but it's much less likely. I would verify that you have a P17 before jumping to get your wastegate ported.
More boost creep info
Old Dec 29, 2004 | 11:33 PM
Krinkov's Avatar
and for those with any confusion TBE stands for Turbo Back Exhaust. Also the stock STI up-pipe is already catless so there is little benefit to running an aftermarket up-pipe
Old Dec 29, 2004 | 11:48 PM
awns729's Avatar
Car Info: want a WRX
you may want to search for 'exhaust diagram'
theres a few threads on it that may help you.
RallySportDirect
Miscellaneous
Nov 12, 2008 08:46 AM
Indirecked
Jun 23, 2007 07:31 AM
gdbimpreza
Mar 3, 2005 12:12 PM
gdbimpreza
Jan 20, 2005 05:25 PM
TRM
Mar 24, 2004 12:58 PM
