What's Next
Old Oct 12, 2003 | 09:20 PM
midnightwrx's Avatar
Car Info: 2004 subaru sti
What's Next
I have an STI slammed on JIC FLT A2 J-spec, TXS RFL BOV, Blitz DTT, Tanabe Racing Medallion Exhaust, Injen Cold air intake.
What should I put on next. Boost controller, Guages (EGT, Air/Fuel Ratio), or downpipe? I really need some advice.
Old Oct 12, 2003 | 10:09 PM
Downpipe. Skip the bost controller, F-Con, or anything like that. I would also take off the intake. The BOV is also costing you a little real-world speed but I can understand if it's worth it to you for the sound. What the STi is DYING for is a good downpipe- the stock piece is horrible. If the Tanabe is any good at all, you will notice big gains with a good downpipe like the Vishnu twin dump dp.
Old Oct 14, 2003 | 07:08 PM
mrtImpreza's Avatar
Car Info: 2004 white STI
I noticed that you have the TXS RFL BOV on your sti. Does it have a lot of clearance on your hood or are you rubbing because i just recently installed the same bov and it is rubbing on my hood and i still haven't got anything back from Turboxs. Let me know whats up.
Old Oct 14, 2003 | 08:11 PM
No mine does not rub on the hood. My friend had the same problem. All you have to do is rotate the BOV so that is blows the air down instead of blowing the air into your hood. You will have an ample amount of clearance. This BOV is extremely loud. I love it!!!
Old Oct 15, 2003 | 06:58 PM
mrtImpreza's Avatar
so just turn the bov so that the outlet is facing down towards the ground? i was also wondering if yours made a quick shsh on low boost but then on high boost it made the long shsh because it sounds weird when i am not at full boost and it goes off.
Old Oct 15, 2003 | 11:55 PM
Yes, just turn the outlet facing down towards the ground. No worries, mine does the same thing. This is just one of the loudest if not the loudest BOV on the market.
JSTTURBO
Jan 6, 2003 09:05 AM
bluepearlej20
Dec 22, 2002 09:51 AM
veloLexus
Dec 11, 2002 10:55 PM
Zoeb2s
Nov 30, 2002 10:24 AM
Choku Dori
Nov 24, 2002 09:02 PM
