sti stage 1 by vishnu
Old Jan 24, 2004 | 11:45 PM
Mach5WRX's Avatar
Angry Dan
Car Info: 05 Evo VIII
Anyone order this yet?
Old Jan 25, 2004 | 12:19 AM
dashiet's Avatar
i will be just getting the chip...do u know how much that will cost me with the tune?
Old Dec 8, 2004 | 06:10 PM
qbbraveheart's Avatar
Car Info: Sold my 05 Evo...Carless for a while...then 05' WRB STi whenever lol :(
didnt want to bring this back but...
its been a while...
anyone else running a Stage1?
its a catted TBE correct?
any boost creep?
Thanks!
Old Dec 8, 2004 | 09:17 PM
STiPilot's Avatar
Car Info: '10 WRB STi SE / '09 BMW K1300S
Originally Posted by BAN SUVS
Vishnu STi exhaust customers have not reported boost creep issues thus far. I do not know if it is because the exhaust doesn't induce it or the Xede takes care of it, but as far as I know you can't tune out boost creep if it's gonna happen. So far only the standard exhaust, which uses a bellmouth downpipe, fits on the STi as the Signature divorced wastegate tube doesn't clear the gearbox.
My APS 3" TBE w/hiflow cat did not have any boost creep issues, either. Recently my cat broke so I went catless until I can get a replacement. As soon as the cat come off....MAJOR boost creep issues (20-23psi in 4th+ gears)
I would guess that Vishnu's exhaust would behave the same if no cat?
Old Dec 8, 2004 | 09:57 PM
thats what I want to know
Old Dec 8, 2004 | 10:11 PM
Actually it comes down to which turbine housing you have. Early STis that had the VF39 with the smaller P17 housing have much more boost creep issues than the VF39s that came with a P18 housing from the VF30/34. IIRC, you got your car early, so it has the smaller housing right? In your case, you would need the wastegate ported to run catless.
Old Dec 9, 2004 | 06:22 AM
Egan's Avatar
its been a while...
any boost creep?
Thanks!
Vishnu Stage 1 w/ ECUtek reflash on an 04:
https://www.i-club.com/forums/engine-power-ej25t-sti-2006-wrx-90/my-270whp-christmas-present-81263/
The exhaust is indeed catted. I get slight boost spiking when it's cold outside up to 19-20 psi at WOT (although it only did it the first few days, so the ECU may have adjusted now). The car is flashed to run at 17-18 psi. Other than that, it's nothing but smiles.
Old Dec 9, 2004 | 01:41 PM
https://www.i-club.com/forums/showthread.php?t=81263
D'oh!
I forgot about that one
Thanks!
Old Dec 11, 2004 | 08:00 PM
cooter's Avatar
Interesting.
I have an '05 STi with a Vishnu TBE with custom test pipe (yay catless). I have no boost creep at all, and in fact can't make enough boost in the midrange (maxes out at ~16psi). This is with the xede.
Is the p17 or p18 designation stamped somewhere visable with the turbo still on the car?
Old Dec 11, 2004 | 09:58 PM
resident smurf's Avatar
Car Info: a prius, a miata, & 2 m3's
i have the XEDE and a turboXS stealthback... awesome setup...... no boost creep problems
pulls hard and smoothly in every gear.
Old Dec 15, 2004 | 09:21 AM
phucvtec's Avatar
Car Info: 2003 Subaru Impreza WRX
Im not new to the scene, but Ive taken a year off so to say. I have a question, but there's a good chance that its been disected over and over already and I just havn't read about it yet... sorry
I current own a 2003 WRX and have a cobb stage 2 w/ vishnu turboback setup. Question is, how much different is a turboback setup for an STi? Reason I ask is that Ill be purchasing either an older 04 STi or a new 05 shorlty, and Im wondering if it would be worth my time to strip the turboback and have the ecu flashed back to factory before selling/trading my WRX.
Thanks ladies/fellas....
Old Dec 15, 2004 | 10:17 AM
Max Xevious's Avatar
BanHammer™
Car Info: 2014 Forester XT
depending on which turboback you have from Shiv, the signature series with the cat in the downpipe will not work with the STI, the cat cannot clear the tranny
iirc, the other exhaust will fit with no issues
Old Dec 15, 2004 | 10:39 AM
Vishnu's Avatar
Car Info: 996 Turbo,Gallardo,BMW 335,125cc shifter kart,etc
The signature exhaust was modified last month to fit with both the STi and the WRX. We just had to rotate the cat and move the wastegate bypass tube a bit
Shiv
________
Dispensaries
Old Dec 15, 2004 | 11:56 AM
phucvtec's Avatar
Thanks for the replies! I do have the signature series turbo back, purchased about year and a half ago. Considering that revisions were made recently, is it possible to use the old system with the replacement of a few pieces? In otherwords, is it possible for me to purchase a new down pipe/cat/intermediate and use the preexisting muffler portion or something to that effect?
All things considered, it probably does not really matter anyway, cause Ill likely sell the vehicle as is, but chances are I will never get what I want for it.
Thanks for the helf!
