STi running lean @ WOT
Old Sep 5, 2015 | 02:52 PM
rprasad1989's Avatar
Looking for some help... I have a 2011 STi and my car is running lean at WOT.
I have a stage 2 91 Octane OTS map from Cobb via Accessport
Stock intake (not for too much longer)
Here are my mods: Cobb Catted Down Pipe Invidia Q300 exhaust Please Help!
Old Sep 5, 2015 | 09:58 PM
CHESTON's Avatar
Car Info: AW Pig-STI
If you are running lean at WOT, then first, i suggest you avoid running at WOT until you get it Pro-Tuned.
Where are you located at anyways, maybe we can recommend some tuners to you.
Second, if you are already running lean, then i highly recommend NOT putting on any intake mods, as they have the potential to make you run even "leaner". If your ECU hasn't already pulled timing due to knock, it likely will if you add any further mods.
A blown engine isn't worth the risk right now IMO.
YMMV
Spoolem
Apr 12, 2014 08:12 PM
Juelz5420
Aug 30, 2005 08:22 AM
mmboost
Dec 22, 2004 07:32 PM
wonton2049
May 4, 2003 06:29 AM
SmuttyStyles
Jan 1, 2003 06:43 PM
