Sti EJ25t Motor Longeviety, Relaibility & Modability....
Old Feb 27, 2004 | 04:34 AM
andyhidley's Avatar
Car Info: 2002 WRX
"the 1.8t's im used to would run 20 psi reguarly & they have a smaller turbo & higher comp ratio (9.5/9.3-1)
Holy Detonation!!! What kind of fuel did you run to prevent detonation?
Old Mar 3, 2004 | 07:09 AM
RiftsWRX's Avatar
Car Info: 02 WRX WGN
Originally posted by BobbyJ
Lots of WRX's out there making 380+ HP at the crank without any failure of any kind. I ran 18-19 psi through my stock internal EJ-20T with never any type of problem, engine or drivetrain. The EJ-25T in the Sti has better pistons better rods and a better block.
That remains to be seen. If anything we've been documenting MANY failures of the stock pistons in the new EJ257's, on NASIOC. The hypereutectics are very fragile, it would seem, to detonation of even the mildest sort, and cracked ring lands or blown rings seem to be common.
Also, bearing failures due to high heat/overrev'ing are being cited.
Finally. the crank HP method of determining power is really meaningless. Short of sounding impressive, what always matters is the power made to the ground, as that's an indicator of how the car can really perform.
Jorge (RiftsWRX)
www.ProjectWRX.com
Old Apr 19, 2004 | 09:23 PM
Chibby Goku's Avatar
Car Info: Vakamon WRX
The rods for the usdm 2.5 STi are forged. They are identical to the v7 a v8 JDM STi rods (Quirt Performance and Ron @ Axis).
Quirt hasn't had any problems in his 2.5. I agree with gohan, it comes down to proper engine management.
Old Apr 22, 2004 | 12:15 AM
SsTiNgEr77's Avatar
Car Info: 2002
its a great car, you will be happy with it, and its not as hard to maintain as an audi, and lot more options vs it... but if you are stuck on audi, why not purchase an bi - turbo s4? those are very nice...
Old Apr 23, 2004 | 10:07 AM
insaneSTi's Avatar
Car Info: Blue STi +Red del Sol VTEC
Stroke is the same the bore is different. STi crank is forged chromoly.
Old Apr 25, 2004 | 03:09 PM
Kay95's Avatar
if the crank in the STI is forged chromoly I dont think having a 4mm longer stroke is going to be a problem
i would be more worried about detonation than anything because of the pistons but the rest of the short block looks good and the reason the USDM STI has a lower redline then the JDM is because of emissions
