recommendations
Old Mar 31, 2008 | 12:48 AM
june.rs's Avatar
Car Info: 07 pearl white wrx
recommendations
howz it guys thinking of slapping a vf34 turbo, fuel pump and, and of course cobb ap. on my 07 wrx. any recommendations would help. thanks for looking.
Old Mar 31, 2008 | 01:04 AM
04caliwrx's Avatar
u have that great 2.5 go with something bigger.....a well tunes 2.5 with a 20g will have little lag and get you some huge whp gains, also the cost will not be much more then your vf30 set up. Just something to think about, hope this helps.
Old Mar 31, 2008 | 01:19 AM
june.rs's Avatar
awh
but im not really going to go all out just something with a little gain. looking more to factory settings ish.
Old Mar 31, 2008 | 12:25 PM
Bran808's Avatar
The VF34 is a great turbo and will give you a noticeable improvement on your 2.5L. But, like some others have said, and probably will say, they wish they had gone bigger the first time. (Myself included) You're lucky that you've got a 2.5 as compared to the older 2.0L.......that extra low end grunt will allow you to run a bigger turbo and not get as much lag. I'd say EvoIII 16G would be the smallest , but would probably personally recommend an 18G or bigger. It also depends on what you plan to do with the car as well as your driving style and how you want the car to perform. Buy "big enough" injectors the first time so you won't have to change them out later. At least I wish I did....
Old Mar 31, 2008 | 12:28 PM
AngrySubyWagon's Avatar
Car Info: ghey e-rights activist
LOL...same here about the injectors. That is one of the sole reasons i'm not going rotated mount...i refuse to do injectors again.
Old Mar 31, 2008 | 12:29 PM
shaggadelic's Avatar
i know that the 06+ WRX'S comes with big injectors and a better flowing fuel pump.
i belive the injectors are 550cc or 565cc someone correct me if i'm wrong
Old Mar 31, 2008 | 01:33 PM
june.rs's Avatar
thanks guys
but my car is daily driven so the vf is the safest option. i was thinking of the mhi 18g but a safe turbo set up is... well enough for me. thanks for your honest opinions. i sahould have the vf set up next month. i already have the sti top mount on. thnaks again.
Old Mar 31, 2008 | 01:47 PM
Bran808's Avatar
Yup, that's correct. The stock '06+ WRX injectors flow about the same as the JDM STi Pinks. That'll work fine for a vf34 or 39, but anything 16g or larger would probably need 650's or more.
Any turbo can be safe as a daily driver, as long as it's installed and tuned properly. You can safely tune/daily drive a FP Green, Red, GT30 etc.... It all depends on how you plan it out.
Old Mar 31, 2008 | 01:55 PM
reid-o's Avatar
banned
Car Info: .
Also choosing your hotside often has more of an impact on spool than the compressor side.
Staying with a td05 will always spool fairly quickly, even with a 20g compressor, and the td06 will almost always have an impact (although most feel insignficant) on spool.
But choosing to go with a td06 hot side will almost always affect spool (but will yield more top end). I think several people here run the t0618g for example, which is the bigger hot side as opposed to the td05 version.
The same is true with the Garret turbos. Most concentrate on the compressor, but choosing the hot side normally has the most significant affect on lag and top end--.82 versus .63.
I'd also recommend any of the td06 turbos (18g, 20g or green) and some larger injector.s
Old Mar 31, 2008 | 03:29 PM
bpang1's Avatar
Car Info: '04 WRX Wagon
Safety is relative...tuning is the key.
I say get the larger turbo if it isn't too much more money. Might as well get a bigger bang for your buck than settle for cheapest upgrade.
Old Mar 31, 2008 | 04:34 PM
cmm929's Avatar
Car Info: 2003 Jeep Wrangler 8" lift
Injectors
HAHA Shoulda just gone the way I did. 860cc all the way. My duty cycle is like 60% at full boost. Got ALOT of room to grow into those babies.
I daily drive my GT35R just fine. Save up a little longer and go with the bigger turbo.
Old Apr 1, 2008 | 03:30 AM
04sleeper's Avatar
so you want more power but just a little bit? what are your goals?? like what hp/tq are you looking to get out of it? there is a lot to be said for the stock turbo and i would suggest doing the bolt-ons before you decide you need to go all out swap. not to mention you are gonna loose your warranty on an 07. i would say do the basics like a dp, catback, and AP and see how you like it. you may just find it was what you wanted without having to swap everything. you could do the bolt ons and use the rest for good suspension bits that will make the drive more enjoyable. just another perspective.
Old Apr 2, 2008 | 02:20 AM
TangMonkey's Avatar
Car Info: 2006 Subaru Impreza WRX TR
I'm debating between the Deadbolt TD05H-18G and the VF34 as well on my '06 WRX...thing is I'm only buying the turbo right now (i found good deals on both). I know I'll need other stuff, but am not quite sure yet what exactly I'll need to upgrade (the turbo will sit in my garage beckoning to be put in).
Will I need new injectors for both or just the 18G?
I already have Walbro 255, dp on the way, and have a cat-back
I am in the process of figuring out which TMIC i wanna buy.
I really only want to reach 300awhp. Also, I'd rather have quicker spool than top end. So for my goal which would be better/cheaper?
Old Apr 2, 2008 | 12:27 PM
subie OCD's Avatar
Car Info: 04 STi
Who is going to tune the car? You should definitely ask the tuner, some tuners like the IHI (vf) turbos and some like the mitsu (18/20g) turbos. If I had a wrx (2.0l or 2.5L), I would put on a vf34 or vf22, big TMIC (APS/TXS/Perrin) and have Ed/EQ tune it. The Green turbo is great but it costs more and could lead to a more expensive setup.
That said, if you are already considering a turbo upgrade, have you considered buying an STi? I'm not hating on your car, its just that I have seen people countless times, upgrade thier wrx (turbo, suspension, etc..) to only partout soon after and buy an STi....hell...I'm one of them Again, I'm not trying to put down the wrx, its a great car and I do miss my 02 wrx wagon (loved the hatch) I'm just giving you my experience.
It all comes down your goals and budget (the STi is more to maintain/insure).
Good luck.
Old Apr 2, 2008 | 03:44 PM
Lboogie's Avatar
banned
Car Info: 2007 WRX Limited | vf43'D
STi tmic & VF series turbo + tune = good enough? If they are Subie parts maybe the warranty has hope of surviving?
