people with FP green check in
Car Info: 04 STI
SOO i have just ordered my entire turbo set up... i have a 04' STi, just curious what numbers have u guys hit with your FP green set up?
Car Info: 04 STI
hmmm ok well iam gonna be running....
perrin FMIC
perrin fuel rails
PE 850CC injectors
custom intake from GST
8CM housing
3' intake inlet
and all be running 100 octane just about all the time.....
perrin FMIC
perrin fuel rails
PE 850CC injectors
8CM housing
3' intake inlet
Car Info: '04 v.2 FPGreen STi by GST Motorsports
btw-ive got almost the exact same set-up on my white '04 STi, but with meth...!!!
good luck...!!!
Car Info: 04 STI
i'm using the SMC Meth Kit (link below). i got mine directly from SMC, because i wanted the tank mounted in the trunk intercooler location. SMC modified a trunk intercooler tank and provided longer hoses for my application. nothing special...you just have to ask for it. (GST can get it for you too) the only problem i'm having is the "LOW" (on meth) indicator on the controller is always on. maybe a bad sensor...really havent had time to look into it. other than that...no issues at all with the meth kit. at my style of driving, i'm barely using the stuff. great for passing, freeway on ramps, wide open highway...etc.
i think the green is the perfect turbo for daily driving. my opinion is a little scued since ive never driven the turbo without the meth kit on...(and probably won't). for daily driving, you'll hardly notice its a different turbo than stock. but once you step on her...OMG...goodness all around...!!!
as far as numbers, GST may have that for you with my car. i think i did just over 300 like Ed said. add the meth...and i'm probably near 350...but don't hold me to that. certainly feels that way on my "butt dyno".
again, i too was real skeptical about the meth. derek will tell you, i really wasn't feeling it as i had concerns about how much i would be filling it, how practical it was, etc. i am 110% glad i did it. if you do it and you mash on that first pull...you'll be glad too...
btw-wise choice of shops. great bunch of "bloaks"...!!! tommy in the shop is a bad azz...!!!
http://www.smcenterprises.com/
Na'im
iClub Silver Vendor
Car Info: 2005 LGT wagon
Last kit I used was Perrin's re-branded Aquamist set up...very stealthy.
Pop the hood or the trunk & you can't see it.
On an 05 STi, got another ~40wtq/20whp.
fourZero
Jul 5, 2009 08:11 AM
Choku Dori
Feb 19, 2009 05:12 PM
