Make your own blow off valve?
Old Sep 21, 2007 | 09:38 PM
Impretzle's Avatar
Car Info: 95 Impreza Wagon... 1.8 Litres of fury!
Why do people spend 100-200 dollars on blow off valves when you can just disconnect and plug the recirculation hose, and put a filter on the end of the stock bypass valve? Is it bad to do that for some reason?
Old Sep 22, 2007 | 01:05 AM
Vladi's Avatar
In Russia, Title Choose You.
Car Info: Everywhere
omg....lol
ghetto fabulous
Old Sep 22, 2007 | 01:23 AM
wrxisthebest's Avatar
cause it doesnt work, cause ur stock bpv let air through the valve slowly and doesnt hold the air in completely, if u do it, when ur car gets warm u will have an uneven idle!
Old Sep 22, 2007 | 03:53 AM
03_Impreza_Al's Avatar
Lessons learned =)
Old Sep 22, 2007 | 12:40 PM
Bcheck07's Avatar
Car Info: 2006 red wrx ltd
sounds like u found out the hard way????
Old Sep 22, 2007 | 12:49 PM
ya i did, i drove for like 5 minutes, i loved the sound it made, nice swoosh, but then i was at a stop light and my rpms would rise ad drop like no other, so i drove home freakin out and then when i got home put my type h bov back on, i am tryin to find out if there is a way to make it work, like weldin the hole or somethin
Old Sep 22, 2007 | 12:54 PM
Impretzle's Avatar
Hmmm well thanks for your thoughts / experiences. I was thinking maybe a harder spring or something might make it work better, or a gasket of some kind. The aftermarket valves can't be that complicated.
Old Sep 22, 2007 | 12:57 PM
a hard spring wont do anyhtin if u look at ur stock bpv, look at the valve their is an air outlet port for it, the tiny as circle in the center is it, when air builds up in ur tmic that circle goes down and allows air to go through slowly
WRXTURBO
Dec 21, 2011 09:32 AM
RallySportDirect
Engine and Drivetrain
Nov 24, 2009 12:54 PM
Black797
Aug 17, 2007 09:15 PM
dgflwrx
May 12, 2003 02:21 PM
