I need help!!!
Old Oct 19, 2004 | 01:26 PM
sfwrx2's Avatar
Car Info: 04 aspen white sti
Unhappy I need help!!!
Here's my mods:
up pipe, down pipe, ported wastegate, apexi intake on an 04 sti
heres my problem:
irratic idoling from almost stalling to 2000 rpm, fuel cut at random rpm
It just started today when I started the car(first start today) it also gets speratic acceleration around 2000 rpm but not in every gear.
Any suggestions?thanx
josh
Old Oct 19, 2004 | 01:40 PM
Paperchasin's Avatar
Car Info: Comeback?
I'd say its the intake...try running stock intake and see wut happens....are u running an aftermarket BOV too??
Old Oct 19, 2004 | 01:51 PM
sfwrx2's Avatar
no bov. why would the intake cause this kind of problem its pretty much just a filter
Old Oct 19, 2004 | 10:41 PM
resident smurf's Avatar
Car Info: a prius, a miata, & 2 m3's
try resetting the ECU. unplug the terminal and hold ur foot on the brake. u need a 10 or 12mm socket for this i think.
start the car back up and see if the problems still there.
Old Oct 19, 2004 | 11:17 PM
Rocket Man's Avatar
Car Info: it's nice
josh.
This is only common because the car's setting is not adapt to the modifications.
Something I have done is letting the car sit and idle for 10 minutes. The ECu will slowly learn idle.
I'd suggest Engine managment for optimum potential of your mods.
unstble
Mar 21, 2008 09:09 AM
resident smurf
May 30, 2005 08:17 PM
Eggman's-STI
Oct 5, 2004 10:43 AM
disque71
Apr 13, 2004 11:27 PM
brucelee
May 28, 2003 09:47 PM
