Hondata intake manifold 'heatshield' - $60
Old Aug 12, 2004 | 01:20 PM
gpatmac's Avatar
http://www.hondata.com/heatshield.html
Worth investigation or just another fad?
Old Aug 12, 2004 | 01:52 PM
SsTiNgEr77's Avatar
Car Info: 2002
i'd investigate, its big in the honda world, i didn't even know they had one for the wrx...
Old Aug 12, 2004 | 02:56 PM
gpatmac's Avatar
$60, I may too.
Old Aug 12, 2004 | 03:00 PM
RoadSpike's Avatar
That is REDICULOUS
you know how hard it is to heat air? its not the easiest thing in the world so the volume that flows into the engine is minimally effected. (A/C backround)
The real heater on the throttle body is the coolant lines that are attached to it. If you want the same effect look up the throttle body bypass on scoobymods.
Old Aug 12, 2004 | 03:47 PM
SsTiNgEr77's Avatar
Car Info: 2002
Originally Posted by RoadSpike
That is REDICULOUS
its more for piece of mind, everyone who used to own a honda if they got a IM, they would always just add the plastic gasket to ease their mind that they've covered every step for the im process,
and some ppl have dyno'd to see gains, but i beleive gains within +3/-3 hp / tq are just conditions in which the dyno was ran
Old Aug 12, 2004 | 06:33 PM
RoadSpike's Avatar
Yeah i see your point i'd prolly do it too if i thought it really mattered. Definitely would be the last thing i'd do.
Old Aug 18, 2004 | 06:27 PM
TreyS's Avatar
Car Info: 2004 WRX STi
some racers swear by it in the honda world.
Old Sep 1, 2004 | 05:06 PM
kewldan's Avatar
From: Houston, Texas "Drive it like you stole it.." 13.034 @ 105.19 mph
Car Info: Aspen White 04 STI, Silver 03 RS (wife's car)
Hey speaking of heatshields, how bad is it to remove the one off of the turbo? will it melt or deform the hood? what do you guys think? Has anyone done this?
Old Sep 2, 2004 | 01:02 PM
TreyS's Avatar
Thumbs down
If you have a TMIC, w/o the heatshield, you will add heat to it.
A hot TMIC is not very efficient (heatsoak).
Old Sep 11, 2004 | 04:45 AM
Group B's Avatar
Dahveed aka Robin Hood
I used to build BMW 2002's, and you would always install a phenolic (plastic) spacer in between either your downdraft or sidedraft carbs and the intake manifold.
The principle is the same.
But then I also bypassed the coolant headed to the intake manifold...
E30 M3's also do the intake manifold spacer mod, so its prolly worth doing.
Old Sep 18, 2004 | 02:11 PM
Rocket Man's Avatar
Car Info: it's nice
i had one and I couldn't tell the difference but they say say it did. It's just a plastic piece that adds a little space between the hot block and the intake manifold.
jondl
Mar 10, 2009 02:54 PM
Speed Element
Feb 22, 2008 04:15 PM
NORCAL STI
Aug 4, 2006 11:43 PM
gruppe-s
Nov 18, 2005 01:42 PM
ultrab20
Jun 20, 2004 05:48 AM
