High RPM Problems Please help.
Old Feb 6, 2009 | 09:51 PM
  #31
Woodward's Avatar
banned
Car Info: 2006 Subaru Impreza WRX TR
That's not boost creep.
Old Feb 7, 2009 | 06:45 AM
  #32
srt2stiguy05's Avatar
Car Info: Impreza WRX STi
then what is it?
on another forum i found a thread a guy stated he had the same exact problem and i looked at my boost gauge it creeps up psi slowly
Old Feb 7, 2009 | 08:37 PM
  #33
Woodward's Avatar
banned
You'd have a CEL and I believe code P0244 if you had boost creep. At least that's what happened when my car would do it.
I'd say there's something up with your 02 sensor then if that's what the code states.
Old Feb 7, 2009 | 08:42 PM
  #34
Woodward's Avatar
banned
Also, why are you @ WOT above 7k rpm? I'm still saying that it's the rev-limiter around 7200rpm that you're hitting. Red line is 6500 on your car I believe.
Old Feb 7, 2009 | 10:40 PM
  #35
Redline is 7k rpm on STi models, rev cuts at 7500rpm it would depend on how much overboost you are having whether the light comes on for the WGA p0244 code.
Lets say my VF-39 stock pushes .1 MPa boost, and with a catless DP the boost raises to .14 MPa and it's not enough over boost to throw the cel then it will infact be boost creep. and if i go over .14 MPa boost level and it throws a cel then it isn't safe to drive the car until that is fixed.
I don't think the O2 sensor is any concern since it's not the Main O2 sensor which tell the PCM if the vehicle is open or closed loop.
Old Feb 7, 2009 | 10:44 PM
  #36
Woodward's Avatar
banned
My bad, 6500 is for the 05 WRX.
Old Feb 7, 2009 | 10:49 PM
  #37
Yea, I'm just saying that it might be higher boost but not high enough to throw a cel
Old Feb 7, 2009 | 10:54 PM
  #38
wrxisthebest's Avatar
you dont have boost creep
your injectors are dirty...lol...
the only thing i could say is go back to stock and work from there
Old Feb 7, 2009 | 11:03 PM
  #39
Well if that is a real answer I am changing them anyways
Old Feb 7, 2009 | 11:09 PM
  #40
just throw some injector cleaner in and see if something changes
Old Feb 7, 2009 | 11:10 PM
  #41
Woodward's Avatar
banned
Your car is dirty.
Have you taken it to Subaru yet and at least had them take a look at it? Maybe by just talking to a service tech. you can see exactly what's wrong.
Old Feb 7, 2009 | 11:12 PM
  #42
Your car is dirty.
ya, i know, my Wrx is a DG...
he should definately go to Subaru, but the fact that he has the Utec in there will make it hard for Subaru to look at it.lol
Old Feb 7, 2009 | 11:17 PM
  #43
It only takes 10 min to uninstall the UTEC.
That is a good Idea though i only use 94 Octane. I will through some in tomorrow since i am running low on fuel.
Old Feb 7, 2009 | 11:21 PM
  #44
make sure to fill up when you put it in.
see if that fixes your issue.
but seriously. go to stock and have Subaru check it out.
they will fix it under warranty with your low mileage...
  #45
Woodward's Avatar
banned
Depends on the dealership. Some know their way with mods, some won't even talk to you about it.
