High RPM Problems Please help.
Old Feb 4, 2009 | 08:41 AM
slimboiphat's Avatar
Car Info: Betty
Originally Posted by srt2stiguy05
Really mine does it 4th-6th at WOT.
im scared to dyno it because of that issue.
have you taken urs to the dealer/shop to see why it was doing that?
Old Feb 4, 2009 | 08:43 AM
Car Info: Betty
Subaru has like a killsafe... if your driving the car too hard at a super high RPM.. it will shut the the engine off... You either have to shift into the next gear or wait for the car to slow down until it starts back up... im not sure if thats what you experience when you say it felt like hitting a wall
oh great. just ruined my fun...
srt2stiguy05's Avatar
Car Info: Impreza WRX STi
yea and i WOULD NOT get your car on a dyno OR tune it until all engine codes are cleared and you know its running fine...
the check engine light is just for the rear O2 sensor it isn't going to harm anything
Old Feb 4, 2009 | 08:44 AM
not yet i wanted to see if someone fixed it.
when i cleared the code and did a freeway pull 100-80 coasting in neutral all the dash lights come on, put it back in gear and they turn off.
Old Feb 4, 2009 | 08:48 AM
im sure if you take it to a tuner they can remove that from the ECU...then you can blow your engine if you want
well as long as the car is running smooth then I would get it tuned. Once you get it tuned the tuner should disable the rear O2 sensor so that code will not continue to appear
Old Feb 4, 2009 | 08:54 AM
Car Info: Betty
[QUOTE=stupidchicken03;2511634]im sure if you take it to a tuner they can remove that from the ECU...then you can blow your engine if you want
lol
thanks you srt/stupidchicken for clarification.
Old Feb 4, 2009 | 08:56 AM
[QUOTE=slimboiphat;2511642]
lol
not a problem:wave:
Old Feb 4, 2009 | 10:39 AM
I heard this is in fact Boost Creep how do i fix this issue??
Old Feb 4, 2009 | 04:32 PM
anyone???
Old Feb 4, 2009 | 04:47 PM
have fun
https://www.i-club.com/forums/search...archid=1521139
Old Feb 5, 2009 | 06:30 PM
Thanks that is very helpful
Old Feb 5, 2009 | 07:24 PM
Woodward's Avatar
banned
Car Info: 2006 Subaru Impreza WRX TR
Are you hitting the rev limiter??
Old Feb 5, 2009 | 08:01 PM
Nope it's boost creep. because when i hit full boost at 3,400 rpm .11 on the gauge the boost slowly goes up to .14 then cuts out and it sucks
Old Feb 6, 2009 | 10:13 AM
KOSTI's Avatar
Car Info: Black On Black Wingless 05 STI
Question:
Do you get a check engine light + flashing cruise control light? Does this happen on cold days or all the time in 4th at WOT?
Usually that will throw a CEL + Flashing Cruise. Pull the code and it will read something along the lines of a wastegate malfunction.
Old Feb 6, 2009 | 05:17 PM
Originally Posted by KOSTI
Question:
cel comes on for bank 1 sensor 2 O2 P0137. But to answer ur question no it doesn't do that.
