Helix Dp
Old Jun 12, 2006 | 10:49 AM
FULLSPECTRUM's Avatar
Car Info: 2005 OBP WRX STI
Helix Dp
Situation:
I have installed a Helix DP and where it connects to the internal wastegate, all the bolts, bolted on properly but one. It looks like the bottom bolt (stud), nearest the intercooler came short (the nut won't screw on because the bolt was to short)
-Made sure that the DP was seated properly.
-All the other bolts and nuts came on perfectly.
What do I do next?
Has anyone had this problem?
Thanks in advance,
Mark
Old Jun 12, 2006 | 11:01 AM
soggynoodles's Avatar
Originally Posted by FULLSPECTRUM
Situation:
I have installed a Helix DP and where it connects to the external wastegate, all the bolts, bolted on properly but one. It looks like the bottom bolt, nearest the intercooler came short. What do I do next?
Thanks in advance,
Mark
Do you mean internal wastegate?
What do you mean by "came short"
Was the dp seated correctly? Was one stud (on the turbo) shorter then another?
Old Jun 12, 2006 | 11:20 AM
Thanks soggy, corrected my post "internal wastegate"
Its seem like the stud was shorter than the others. So the Nut wouldn't screw on. The DP is seated properly. When I turn on the car, I hear no leaks.
- Mark
gruppe-s
Engine and Drivetrain
Aug 11, 2006 05:34 PM
nathanellis
Wanted
Jan 14, 2005 05:29 PM
nathanellis
Jan 14, 2005 04:08 PM
mastros2
Wanted
Mar 20, 2004 03:27 PM
