Good Boost Controler Vc Porting
Old Jan 27, 2005 | 10:06 PM
Group B's Avatar
Dahveed aka Robin Hood
oh no Access Port...good luck!
Old Jan 28, 2005 | 05:09 PM
TitanSTI's Avatar
Car Info: Silver 09 STI
Originally Posted by cdaddy05STI
what is that suppose to mean????????????
seriosuly thouhg, i wanna know too!
Old Jan 29, 2005 | 01:27 AM
Some people have had bad experiences with the AP.
No engine management actually cures boost creep- none. Not even EcuTek. What you CAN do is shut off the fuel cut that happens when you overboost. This is how some people get around it. I personally would get the exhaust I wanted, get tuned, and then see if I was getting boost creep (which is 16 psi + on a stock VF39). If so, I'd then get it ported.
Old Jan 30, 2005 | 12:36 PM
Again, what engine management changes is the boost cut threshold. You are STILL GETTING BOOST CREEP. It's just not cutting fuel. It's not the ideal solution (that would be porting your wastegate or not running catless). Don't confuse not having fuel cut with not having boost creep.
roadkillSTI
Jan 30, 2005 01:10 PM
.:: 808 STi ::.
Feb 16, 2004 11:43 AM
DWNSHFT
Dec 7, 2003 02:02 AM
RBREX
Oct 1, 2003 03:59 PM
digitalroojp
Jan 13, 2003 03:49 PM
